What happens if the @SLEEP below is commented?
Code:WHILE COUNTER < 2 ' 4.608sec Loop time (Loop for 30 mins = 781) @ SLEEP COUNTER=COUNTER+1 'IF GPIO.3= 0 THEN COUNTS 'Bird at box (it's not dark) so continue counting WEND
It TX's straight away and the led on the Pickit1 (receiver) flashes three times (as intended). There is no 5 sec delay from the timing loop though.What happens if the @SLEEP below is commented?
It's as if the timing loop COUNT is just being bypassed, have I set it up right?
If I press and hold down push button GP4 on the transmitter, the receiver flashes the led continually. I would have thought / was expecting that when the push button on GPIO.4 was pressed and held down you would get a four / five second delay before the receiver received anything and started to flash.
Tonights silly question:
How does setting the OPTION reg and WDT then become associated with the loop COUNTER? The WDT has a period of 18ms so setting the bits 111 gives 128*18ms =2.304secs the COUNTER loop should run twice giving a delay of 4.608secs right? But if the program doesn't read COUNTER as being associated with the WDT it's going to count to two in a flash and it will appear that the TX sends the data instantly(which is what is happening). Should the WDT and COUNTER be 'joined' via a 'SYMBOL statement in the program under SYMBOL? or something like this?
Just guessing as I have not done this before...
I hope someone else will jump in on this...Code:WHILE COUNTER <= 2 ' 4.608sec Loop time (Loop for 30 mins = 781) INTCON.0 = 0 @ SLEEP COUNTER=COUNTER+1 'IF GPIO.3= 0 THEN COUNTS 'Bird at box (it's not dark) so continue counting WEND
Hi mackrackit,
I've made the changes and the Transmitter lights the it's reference led about once every nine seconds but doesn't transmit at all (doesn't seem to get that far).
I still can't get my head around how the WDT associates with the loop COUNTER, plus the more I read on this it seems that if the WDT isn't reset back to zero before it reaches FF+1 (I think) it then reboots the program which makes sense....Mmm, more reading and thinking to do, interesting though.
First let me say, this is an awesome thread. I have been meaning to read it from the beginning, but I am a slow reader.
LEDave, WDT in the snippet you just posted works like this:
Assuming PBP knows you are using the WDT, clear WD is sprinkled around the program for you to keep from resetting the chip. But to get to these, the program must run.
@sleep basically stops the program and the chip just, well sleeps. Because of this, the WDT never gets cleared. The WD can wake up the PIC, so when WDT overflows, the PIC wakes up and resumes where it left off. So this is how the WDT is associated with the counter.
Hope this helps
-Bert
Bert,
will this make it work as expected?
Code:WHILE COUNTER <= 2 ' 4.608sec Loop time (Loop for 30 mins = 781) INTCON.0 = 0 @ SLEEP CLEARWDT COUNTER=COUNTER+1 'IF GPIO.3= 0 THEN COUNTS 'Bird at box (it's not dark) so continue counting WEND
