Here is my code:
http://pastebin.com/f456e5db
Sorry it's a bit of a mess. If I comment the "IF" on Line 343, with the corresponding ENDIF, the code runs much more consistently. Also, "Encoder_Counting" at 395 disabled interrupts to do some processing, but only for a few lines while it copies a buffer. If I disable interrupts for the entire routine, one of my problems goes away. The problem was that "Current_Position" got changed randomly. I guessed that my interrupt was screwing with it, so I disabled interrupts for that entire routine. Theoretically, my interrupt shouldn't interfere with that at all. None of the variables there are used by the interrupt. When I copy from the variables which are used during the interrupt, I disable global interrupts. ::Confused::
About assembly interrupts, when I use them I only restore the W register. Do I need to do anything with wsave1, wsave2, or wsave3? I know I have to declare them, but I"m not sure where they get used.
MAtt
