To Generate Sine Wave Using PCPWM of PIC18F4331 (Issue)
Results 1 to 7 of 7
Threaded View
  1. #5
    Default Sine wave using DT interrupts
    I've been interested in this as well. Using the principles of AN655, (only using DT_INTS and HPWM, rather than software PWM), here is some code. Not sure how clean my sine wave is, but it doesn't look too bad on the scope. Might be better if I trim the leads on the breadboard filter. Hopefully someone can have some fun with it. I have a feeling it might be smoother in DT_INTS using an ASM interrupt routine, so that is where I am headed next, thanks to Darrel and Bruce. Will try to give that a shot.
    ;    Circuit Diagram:
    ;    PIC18F2431
    ;   Filter Diagram
    ;               2.7k            2.7k
    ;    RC2  ___/\  /\  /\______/\  /\  /\________ Analog Output
    ;                      ----- 0.1uF      ----- 0.1uF
    ;                       GND              GND
    define OSC 40
    asm
        __CONFIG    _CONFIG1H, _OSC_HSPLL_1H
        __CONFIG    _CONFIG2H, _WDTEN_OFF_2H & _WDPS_512_2H
        __CONFIG    _CONFIG4L, _LVP_OFF_4L
    endasm
    ADCON0 = 000000
    ADCON1 = 000000
    trisb = 111111
    trisc = 111011
    trisa = 111111
    TMR2 = 16
    PR2 = 129       ;set for 19.2Khz HPWM
    LED1 var portC.1
    LED2 var portC.3
    Duty var word
    CCP1CON.3 = 1        ' set to pwm mode
    CCP1CON.2 = 1
    T2CON.2=1
    T2CON.0=1
    STEPCOUNT var byte
    stepcount = 32
    ; Set sine "table" in an array
    sineval var byte[33]
    sineval[1] = 128
    sineval[2] = 148
    sineval[3] = 167
    sineval[4] = 185
    sineval[5] = 200
    sineval[6] = 213
    sineval[7] = 222
    sineval[8] = 228
    sineval[9] = 230
    sineval[10] = 228
    sineval[11] = 222
    sineval[12] = 213
    sineval[13] = 200
    sineval[14] = 185
    sineval[15] = 167
    sineval[16] = 148
    sineval[17] = 128
    sineval[18] = 108
    sineval[19] = 89
    sineval[20] = 71
    sineval[21] = 56
    sineval[22] = 43
    sineval[23] = 34
    sineval[24] = 28
    sineval[25] = 26
    sineval[26] = 28
    sineval[27] = 34
    sineval[28] = 43
    sineval[29] = 56
    sineval[30] = 71
    sineval[31] = 89
    sineval[32] = 108
    timerone var word
    INCLUDE "DT_INTS-18.bas"     ; Base Interrupt System
    include "ReEnterPBP-18.bas"
    ;LOW  LED1
    ;high led2
            INT_Handler   TMR1_INT,   _sine,   PBP,  yes
    T1CON = $31                 ; Prescaler = 8, TMR1ON
    TMR1L = 255
    TMR1H = 254
    @   INT_ENABLE  TMR1_INT     ; Enable Timer 1 Interrupts
    timerone = $FD85                ;gives about 60 htz sine
            pause 5
            'timerone = timerone - 1      'uncomment to vary 60hz sine
            if timerone = $F9FF then timerone = $FF00
    GOTO Main
    '---[TMR1_INT - interrupt handler]------------------------------------------
    sine:
        TMR1L = timerone.byte0
        TMR1H = timerone.byte1
        CCPR1L = sineval[STEPCOUNT]>>1
        stepcount = stepcount -1
        if stepcount = 0 then stepcount = 32
    @    INT_RETURN
    And changing the frequency of the sine (uncomment one line):
    Last edited by ScaleRobotics; - 14th April 2012 at 05:37. Reason: fixed array size
  1. Sine wave
    By Darrenmac in forum mel PIC BASIC Pro
    Last Post: - 18th May 2009, 04:31
  2. Generating 3-phase sine wave..
    By sirvo in forum mel PIC BASIC Pro
    Last Post: - 6th November 2008, 15:07
  3. How to generate sine PWM using 16f877
    By kvrajasekar in forum mel PIC BASIC Pro
    Last Post: - 12th September 2008, 09:40
  4. square to sine wave help
    By TONIGALEA in forum General
    Last Post: - 2nd July 2006, 10:32
  5. PBP Dampened Sine Wave
    By Keith55555 in forum mel PIC BASIC Pro
    Last Post: - 3rd April 2004, 21:01
