how to control the contrast of GLCD
Results 1 to 10 of 10
    Feb 2012
    PERTH AUSTRALIA
    Default how to control the contrast of GLCD
    Hi Guys , can someone point me toward a link to info on how the pic can control of the contrast on a glcd
    the glcd uses a internal gen -10.5v on Vo , with a 10k pot to Vcc ( 5v) , wiper connected to Vlcd
    regards
    sheldon
    [IMG]
    DG-24064-09 _ P234.pdf
    [/IMG]
    Default Re: how to control the contrast of GLCD
    Hi Sheldon,
    What's the voltage at VLcd when you have good contrast? If the voltage is positive then you can drive it directly with the PIC using HPWM and a simple filter. It won't be that easy if the voltage is actually negative, which I suspect it is. But in that case you may look into replacing the mechanical pot with a SPI or I2C controlled potentiometer chip. I'd double check that the datasheet for the pot-chip regarding min/max voltage.
    Feb 2012
    PERTH AUSTRALIA
    thanks hendric the voltage is about -6.0 to -7.5v on the wiper relative to ground for visual of the chrs ,
    is there a way to just switch on/ off a mosfet which is connected from the GLCD negative output ( Vo) to the VLCD pin and adjust the voltage applied depending on the time the Mosfet is on using PWM ? ????
    Jan 2011
    Sydney, Australia
    Hi Sheldon,
    You obviously can't achieve a negative voltage directly from the PIC so you will need some external circuitry (including a negative supply greater than -7.5V).
    It should be possible to drive an inverting op-amp, with a gain of say 2, via Henrik's filtered PWM signal such a positive input will result in a negative voltage at the GLCD contrast pin.
    Just a thought...
    Cheers
    Barry
    VK2XBP
    pwm through an opto coupler would be easy, driving things on the neg bus from the positive side are awkward opto's make life easy
    Feb 2012
    PERTH AUSTRALIA
    the glcd generates the negative supply so using an opto transistor connected to the negative Vo output of the glcd to the glcd VLCD input ( contrast control ) is possible , not sure how linear an opto fet would be to adjust the voltage for the contrast though ,
    I had looked at a digital pot , but seems that the voltage cant be negative on the resistor divider network , in respect to the chips supply vdd and grd rails.
    Hello,
    Maybe something like this using a pnp in a open collector configuration. Much like we control a 12v relay with a NPN and a 5v mcu. Set the PWM to 50% duty and adjust the contrast pot to good level. Now you should have a +/- contrast changing the duty. Basic idea only. Might want to add a resistor and cap to the pwm line to smooth it out.
    Feb 2012
    PERTH AUSTRALIA
    Hi Mark , thats would be worth a try , i am thinking perhaps reverse in the transistor control to the negative voltage , as it appear that to see the char on the screen the pot is biased toward the negative supply , if that works why is it i cant find an example on the web doing this ???
    Hi Longpole,
    You can't switch the negative voltage without a voltage translator. It is approximately -10v below the pic ground vss.
    Think of the contrast pot as a simple voltage divider connected between +5v and -10v or 15v total.
    Using a pnp and pwm you can adjust the positive node of the voltage divider up or down by 5 volts. This in turn moves the center point of the voltage divider (Vlcd) up or down. It can be in negative voltage range as long as the pot is adjusted towords the -10v end. So in theory it should control the contrast. Hope you can make it work.
    Feb 2012
    PERTH AUSTRALIA
    ill try it on the weekend see how effective it is
  1. Easy LCD Contrast
    By Melanie in forum Schematics
    Last Post: - 6th January 2015, 00:46
  2. Samsung 5'' GLCD 320x240 on sale, who knows control it?
    By HYETİK in forum mel PIC BASIC Pro
    Last Post: - 6th April 2009, 21:38
  3. LCD contrast
    By Demon in forum General
    Last Post: - 21st March 2009, 16:19
  4. Controlling LCD contrast?
    By jblackann in forum mel PIC BASIC Pro
    Last Post: - 27th December 2006, 02:31
  5. How to change contrast LCD?
    By MCU Destroyer in forum mel PIC BASIC Pro
    Last Post: - 3rd July 2005, 13:16
