Help/Explanation needed
Results 1 to 3 of 3
    Feb 2010
    Default Help/Explanation needed
    Hi all. I'm new to this forum and to PicBasicPro and need some help.
    This is my code:
    TRISA = 0
    Pause 250
    High PortA.0
    Pause 250
    High PortA.1
    Pause 250
    Low PortA.0
    Puase 250
    Low PortA.1
    Goto Main
    (Tried this as well: Symbol LED = PORTA.0, High LED AND PORTA.0 = 1)
    My expectation is that PORTA.0 will go high, then PORTA.1 will go high while keeping pin 0 high. But this is not the case. When I make any pin high, the rest go low. Is this the correct bahaviour?
    I underdstand PortA = 7 will cause pins 000111 to go high, but surely portA.x should not affect the state of the other pins? or am I wrong?
    I'm using a PIC16F676 with PicKit 2 Programmer.
    Thanks in advance
    Welcome to the forum.
    The PIC you are using has analog on PORTA. You will need to make it digital.
    Add this near the top of your code
    ANSEL=%00000000
    CMCON=%00000111
    And this thread will be some good reading
    Feb 2010
    Thanks a million. it worked!
  1. ASCII Viewer Needed
    By sougata in forum mel PIC BASIC Pro
    Last Post: - 19th January 2008, 05:29
  2. Code space needed with MPASM??
    Last Post: - 7th September 2007, 10:24
  3. Programers Needed Still !
    By picawiner in forum mel PIC BASIC Pro
    Last Post: - 5th June 2007, 13:51
  4. Newbee Hardware PWM clarification needed
    By emmett brown in forum General
    Last Post: - 9th July 2006, 09:18
  5. Circuit needed to allow a PIC to turn something on or off
    Last Post: - 12th October 2005, 21:17
