Stupid simple question.....
Results 1 to 19 of 19
    Jun 2008
    oy...
    Thanks guys, you rock..
    How I wish I could be using my Arduino for this project..
    www.theLanguageBear.com - Multi-Lingual books for kids and adults of all skill levels.
    Jun 2008
    Default Another dumb ass problem
    I really hate this stuff.... it makes me want to stab myself in the eyeball with a fork.
    I'm measuring 3v from Pin1 (GP1) on my 12F683.
    I'm using a 3v coin cell. It measures 3v.
    I connect a LED to Pin1, it lights.
    YAY! Next frickin challenge....
    I connect a small vibe motor to my 3v battery, it vibrates like crazy. Yay.
    I connect my small vibe motor to Pin1 (measuring 3v) It does absolutely nothing.
    I connect the LED to Pin1.. it lights..
    I connect the motor to Pin1 ... it does nothing
    I punch stuff... that doesn't help.
    I don't know what else to try...
    The vibe motor draws about 35-40mA
    I see that the IO pins supply 25 mA but the GPIO can supply 90mA...
    What's the difference?
    Quote Originally Posted by chien_fu View Post
    A single pin can put out a max of 25mA, but the entire GPIO (all output pins) can put out a max of 90mA. You could use a transistor, or you could have two pins control the motor (and hope start current would not be too high).
    Jun 2008
    So I tried driving it with two pins but something else is screwy now....
    This is what I have:
    OUTPUT Pin1
    output Pin2
    Startup:
    for startupalarm = 1 to 4
    high 2
    high 1
    pause 5000
    low 2
    low 1
    pause 5000
    next startupalarm
    It seems that "high 2" does not actually switch the pin high, but just ticks it high for a split second. "high 1" switches the pin high and it is held high for 5 seconds until it is switched low...
    This is the same regardless of which pins I use. The line of code immediately preceding the pause command works, all others do not. Nothing else is connected to the chip, it's all by itself on a breadboard.............
    You're suffering from what is called a RMW problem (read-modify-write). The way the PIC works when setting a single bit in a register, like the GPIO-port in this case, is to first read the whole register, then set the bit in question and finally writing the whole register "back".
    Because your motor presents a large a load to the pin (especially at startup) the voltage on the pin will sag or be low. So what is happening is this:
    First you have the High 2. This reads the port (as a byte), sets bit 2 and writes the whole byte back to the port.
    Now you have High 1 which does the same thing but because pin2 is heavily loaded it will read as 0 when the port is read, the PIC then sets bit1 and write back to the port resulting in bit 2 now being reset to 0.
    The best bet is to use a transistor to drive the motor. If that's not an option then write to the port directly, setting both pins at the same time. You do this in the same way as Darrel showed you how to write to CMCON etc - look up the physical adress of GPIO and use POKE to write to it.
    Remember also, you must treat your Motor as an INDUCTOR or RELAY. The back emf could destroy your PIC pin or Transistor switching it. Put that all important Diode reverse-biased across the Motor.
    Post
    +1 .....
    Good answer from Henrik ...
    Last edited by Acetronics2; - 23rd February 2010 at 09:44. Reason: I must RTFM !!!
  1. Really simple question for you experts :)
    By lew247 in forum mel PIC BASIC Pro
    Last Post: - 4th June 2008, 02:43
  2. SIMPLE question
    Last Post: - 5th February 2008, 19:27
  3. Stupid question
    By Meriachee in forum mel PIC BASIC Pro
    Last Post: - 20th July 2007, 06:47
  4. really simple, dumb question
    By picster in forum mel PIC BASIC Pro
    Last Post: - 3rd March 2007, 23:02
  5. really simple adcin question
    By kitcat in forum mel PIC BASIC Pro
    Last Post: - 21st April 2006, 10:06
