pickit 3 and configuration bits.
Results 1 to 7 of 7
    Feb 2010
    Default pickit 3 and configuration bits.
    hi.
    i am battling to get my pickit 3 to work.
    using the examples which are in written in c it works perfect,however when i
    write my little program,nothing happens.
    therefore it leaves me with one conclusion: the configs are not set and i cannot find any literature on how to set these
    eg the mclre_off.how would one set the configs so that my little program will work,bearing in mind that the chip is loaded with my program.
    Feb 2010
    Default configuration settings.
    0so if i try this it should work?
    @ _MCLRE_OFF_3H & _LVP_OFF_4L
    EQU H'FB' // EQU H'7F'
    what about the part where it mentions the equ?.will that be left out.
    will the first line of code work?
    Which PIC are you using?
    Feb 2010
    Default Pickit3 configbits
    The 18f45k20.
    Soory, fussed out a bit, I know what you are asking...
    You must be looking at the inc file in MPASAM Suite.
    Do not worry about the "EQU H'FB" stuff. Just addresses.
    That file tells all of the options and a bunch of other things.
    The file to change or comment of you set the configs in code space is the inc file in the PBP directory. The way they are set up there is what you need.
    Assume you want MCLRE off and I will guess a HS OSC?
           @ __CONFIG    _CONFIG1H, _FOSC_HSPLL_1H
           @ __CONFIG    _CONFIG2H, _WDTEN_ON_2H & _WDTPS_512_2H
           @ __CONFIG    _CONFIG3H, _MCLRE_OFF_3H & _PBADEN_OFF_3H
           @ __CONFIG    _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
    Notice the MCLRE is on the CONFIG3H line.
  1. Presetting Configuration Fuses (PIC Defines) into your Program
    Last Post: - 15th December 2013, 10:54
  2. Warning: Some configuration words not in hex file
    Last Post: - 14th December 2009, 07:25
  3. ADC Problem with PIC16F88 Configuration
    By robert.quaas in forum mel PIC BASIC Pro
    Last Post: - 9th April 2009, 18:46
  4. PICBasic newbie problem
    Last Post: - 12th February 2008, 01:55
  5. 18f4620 Configuration bits
    By Raflex in forum mel PIC BASIC Pro
    Last Post: - 13th September 2006, 21:32
