Using "END" in a subroutine?
Results 1 to 7 of 7
    California, USA
    If the sub is reached from a GOSUB then I guess it would depend on the rest of your program. If the program is not expecting data from the sub or data from an interrupt then it would be ok.
    I'm watching for a pushbutton to pull a port low. When the button is pressed, a subroutine is called that shuts down some external circuitry, finishes all the PIC chores, and then I want all PIC activity to END. Not looking for any more data or anything. No more activity until the power is removed and restored, then the program starts "fresh" again.
    It looks like "END" works fine for what I want. Just wanted to make sure there's no "creepy" side effects or anything.
    thanks!
    Talking
    Hi Steve
    Consider the PBP " END " is an assembler
    label
    ' here page select if needed
    GOTO label ...
    obviously taking care of page issues ...
    functionnaly exactly the same as the STOP command ( that you should use ) ! - may be same asm ( ! ) code I didn't verify -
    STOP creates an endless loop with a CLRWDT instruction + GOTO back to the label at
    the CLRWDT instruction.
    END creates a loop with a SLEEP instruction + GOTO back to the label at the SLEEP
    instruction.
    Either will work, but END saves power. If you need it to goto sleep and never wake up
    just insert an @ SLEEP at your label, and disable WDT, interrupts, etc..
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Talking
    Oops ... forgot the @sleep ...
    Thanks Bruce !
    California, USA
    Thanks Bruce for the insight into the inner workings of STOP and END.
    I forgot about @ sleep.
    Thanks much!
    steve
  1. Multiple RETURNS within a single subroutine
    Last Post: - 21st June 2009, 17:43
  2. Pulsin within subroutine
    By Wesley in forum mel PIC BASIC Pro
    Last Post: - 11th January 2009, 00:05
  3. subroutine with hserin
    By volcane in forum mel PIC BASIC Pro
    Last Post: - 19th December 2007, 03:56
  4. subroutine for picbasic
    By jojokatada in forum mel PIC BASIC Pro
    Last Post: - 19th February 2005, 19:58
  5. Replies: 0
    Last Post: - 28th May 2004, 18:25
