Problems with SERIN2 using PIC16F689
Results 1 to 3 of 3
    Feb 2010
    Default Problems with SERIN2 using PIC16F689
    Dear Sirs,Madams:
    I am having problems to implement Serin2 in a pic16f689.
    This is the code I am using:
    MainLoop:
    SERIN2 Rxpin,84,[STR test8/8]
    'instructions to process incoming data and reply with data (i.e. serout2)
    Goto Mainloop
    Where
    Rxpin: Rx pin (PORTB.5 in PIC16F689 and PORTC.7 in PIC16F877A)
    84: 9600,8,n,1
    test8 declared as var byte[8]
    This code works fine with PIC16F877, waiting for 8 characters to be received before processing incoming data but it does not work with PIC16F689.
    When I run it in PIC16F689, it does not wait incoming data to arrive and executes instructions to process incoming data.
    Your help will be greatly appreciated
    Sincerely,
    Jesús Baez
    PORTB.5 on the 16F689 is analog at power up. Place ANSELH=0 in the top section of your
    code to disable A/D on this pin.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Feb 2010
    Default thanks
    Dear Bruce
    Thanks for your help!
    Jesús Baez
  1. GPS $GPRMC to PIC16F684. Need help with SERIN2
    Last Post: - 27th November 2009, 10:47
  2. Getting SERIN2 to work?
    By BobPigford in forum mel PIC BASIC Pro
    Last Post: - 22nd July 2009, 21:10
  3. SLOW Serin2 and Serout2
    By dragons_fire in forum General
    Last Post: - 26th June 2009, 03:38
  4. SERIN2 digit parsing
    Last Post: - 8th January 2007, 00:15
  5. SEROUT2 and SERIN2 commands
    By bangunprayogi in forum mel PIC BASIC Pro
    Last Post: - 4th August 2005, 10:03
