Yes! Add multi rotor motor conrol to the list, (as well as single rotor). Yes, for the last three links, you might have to upgrade up to a PIC16, or maybe even a PIC18. But I thought I would get an example out using one of the smallest chips supported by PBP to get peoples imaginations going. If the 12f683 can breeze through this, think what a 40mhz chip ( and a little of your imagination and a little of your code) can do. Something very similar was done 8 years ago, see link two. He added a lot of neat features. Too bad I didn't see it 8 years ago, I could have used that......
Only, with this code, you can put your own PBP code into it.
Here are a couple examples of things which perform servo encoding and decoding, with a "little" math in between, ok, and in some cases a "little" extra hardware. There is a lot more than this out there though....
http://www.servocity.com/html/servo_mixer.html Mixer for RC
http://homepages.paradise.net.nz/bhabbott/decoder.html Giving smarts to a dumb receiver
http://rcpilot.sourceforge.net/modules/rcap/index.php A rudder controlling autopilot using a PIC16F876
http://www.u-nav.com/circuitboards/alt3.html An altitude hold device
http://www.fmadirect.com/products.htm?cat=75&nid=6 A very smart receiver stablilizing device .. and more.
http://www.sparkfun.com/commerce/pro...oducts_id=9038 UAV autopilot based on a dsPIC30F4011 (ok a "little" faster than a 12F)
http://www.sparkfun.com/commerce/pro...oducts_id=8785 UAV autopilot based on Arduino chip
