Display Vdd
Results 1 to 8 of 8
Thread: Display Vdd
    Feb 2010
    Thjanks again.
    All received and well understood. But the original question remains : "how do you physically display the current value of Vdd on an LCD?"
    And has been answered IMO.....
    You use some kind of voltage reference chip that produces a stable reference voltage over the whole operating range of your batteries. Let's say that voltage is 2.048V. You connect this reference voltage to the Vref pin on the PIC and set the ADC up to use that pin as Vref+ instead of Vdd.
    Now you create a resistor network between Vdd and Vss and choose the resisitor values so that the voltage over the lower resistor is as close to 2.048V as possible when the batteries are fully charged. You connect this "signal" to the analog input of your choise.
    Now the ADC will give you a reading of 2mV/count.
    There is no way to internally "connect" Vdd to an analog input - except to the Vref+ pin. And there is no way to do measure Vdd without using an external reference voltage.
  1. Hdsp 21xx display
    By Original in forum mel PIC BASIC Pro
    Last Post: - 7th June 2012, 21:07
  2. Replies: 2
    Last Post: - 14th July 2008, 23:11
  3. DS1820 display with 7-seg 4 digits
    By chai98a in forum Code Examples
    Last Post: - 10th April 2008, 14:12
  4. need help on display problem
    By sixty9sandals in forum mel PIC BASIC Pro
    Last Post: - 30th March 2007, 04:57
  5. graphics display
    By adlinsystems in forum mel PIC BASIC Pro
    Last Post: - 12th June 2004, 13:53
