RC5 code for infrared receiver
Results 1 to 24 of 24
    California, USA
    Quote Originally Posted by Dennis View Post
    Hey I recognize that code ... it's from 'Controlling the world from your armchair' aka article.pdf by Les Johnson :-)
    Yep. Works great too.
    Now if you look carefully at the previous posts you'll see mention of the RC5 protocol and here for a more detailed tech dive [HTML]http://www.sbprojects.com/knowledge/ir/rc5.htm[/HTML]
    Thanks. I've read a bit about RC5... I just haven't used it for anything yet.
    Say, the other thing I'll mention is that if you use DT_interrupts (or probably any interrupts for that matter) you may want to turn them off just before the PULSIN command and turn 'em back on afterward. It took me an embarrassingly long amount of time to troubleshoot THAT problem...
    steve
    I posted an example here: http://www.picbasic.co.uk/forum/showthread.php?t=12555
    that makes learning IR button codes really easy. It uses a special capture module on the
    18F2431 that captures everything. High signal period, low signal period, and spits it all out
    to a serial terminal window. You can learn every button code on your remote in just a few
    minutes.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Default cool
    @Bruce - thanks for the cool tips nad the code there, I'm dying to try that as soon as I can source some 18F2431's..order placed but still waiting for them.
    Did you ever manage to get any reliable way prior to the CCP modules and the 18F2431 ?
    @Steve - thanks for the tip about interrupts I am not using any yet but weill heed the warning as soon as I do start with them :-)
    Kind regards
    Dennis
    California, USA
    minutes.
    Yeah... funny about that. Several days after you posted that some 18F2431's showed up in my mailbox. Just a coincidence? I think not.
    Haven't tried them yet. They're still sitting in their cute little black Microchip box.
    Thanks for all the good code Bruce!
    steve
    California, USA
    Last year I bought a device that plugs into a USB port and "reads" IR remotes.
    It shows quite a bit of info... carrier frequency, a visual of the code waveform with high and low times, how many carrier cycles, etc, as well as the button and device code numbers.
    It also has a pretty fair data base that recognizes various codes and tells you what format they are.
    Here's a screen shot of the output:
    http://www.weirdstuffwemake.com/swee...es/irscope.gif
    steve
    Yeah - I used a USBee SX PC logic analyzer...;o) The 2431 approach is a lot faster, and gives me data I can print to text. I fiddled with one version that would even write PBP code for me to re-generate the same IR signals.
    Steve,
    Looks like a handy gadget. Should be pretty easy to write code with the data that spits-out.
    -Bruce
    tech at rentron.com
    Default The hard part about RC5....
    Steve - that does look like a nice gadget indeed :-)
    Bruce - sounds like you have been through a lot of work in efforts to decode the signals.
    @Anand ..that's a nice site :-)
    Unlike SONY protocol which has set pulse sizes for 1's and 0's ,
    I see the issue with decoding the RC5 protocol , it uses bi-phase encoding either a pulse on the first half of a total bit time (denoting a 0) OR the last half of a bit time (denoting a 1) so some code would be required to check the state of the pin.
    There must be some way to measure and capture this....back to the drawing boards I go :-(
    Any thoughts anyone ?
    Kind regards
    Dennis
    Default still trying
    So it seems to decode the RC5 code, after detecting the initial pulse, some sort of check must be done at a regular time interval at the mid-point of each half bit-time since a full bit-time is 1778us (2x889us).
    So after the initial pulse I would have to check midway between the first bit-time, roughly 440us.
    So in terms of the pulses and checks we have the following:
    Start1--Start2--1st BIT--2nd BIT--3rd BIT---...etc
    ____|-------|---------|---------|--------|--------
    1778| 1778 | 889, 889| 889,889 | 889,889|--
    hch__hch____ch__ch___ch__ch___ch__ch
    Header
    check =hch
    ch=bit check
    After initial header check, waste some time and then start testing and collecting.
    So now to find the right code.
    Dennis
    Quote Originally Posted by Byte_Butcher View Post
    steve
    Steve, here's something similiar one can roll on one's own; works only on 'real' serial ports though (NOT USB-to-serial), found it quite useful in a few situations.
    http://www.laser.com/dante/
    Anand
  1. PBP code to read R/C signal from receiver
    Last Post: - 28th October 2009, 22:51
  2. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 22:55
  3. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  4. Loop with two motor and 2 sensors
  5. Making Program Code Space your playground...
