Bootloader For 18F4520
Results 1 to 37 of 37
    Feb 2009
    Southern California
    Anyone have any idea what needs to be done to modify either of the included files to run at 40 MHz instead of 4 or 20? I looked over both hex files and there are only a few lines difference between them, but I have no idea what I'm actually looking at.
    David
    Quote Originally Posted by Luckyborg View Post
    David
    MCS has not provided any source code (that I am aware of) for their bootloader, so I think it would be pretty hard to modify it to run at double the speed. If you don't mind it not working directly through the MCS interface, then you could modify the assembly source code given by the Tiny Pic Bootloader, located here: http://www.etc.ugal.ro/cchiculita/so...bootloader.htm
    And run it beside your MCS.
    .... But Maybe,
    To still use MCS's bootloader hex, you could think about switching PLL settings on the fly in your code. See: http://www.picbasic.co.uk/forum/showthread.php?t=4093
    Maybe you could set the low power interrupt to change it back to 20 mhz when it powers down? Kind of backwards, but might work.
    Walter
    Feb 2009
    Southern California
    I've looked into this a little, but as I have never used mplab and try to avoid assembly my first attempts have failed. If no one has any better ideas, I'll try to look into it more next week. Thanks for the help
    David
    Default 20mhz bootloader and 48mhz code
    Ok, this works for me. I'm using microcode stuidios 18f4550 20mhz hex bootloader file, and change the speed to 48mhz on the fly using Darrel's RTconfig.inc file.
    Will post code tonight for a 18f4520
    DEFINE OSC 48	' Lets work at 48 MHz with our 20mhz bootloader!
    define LOADER_USED 1
    @ #include "RTconfig.inc"  ;Darrel's write to configs while running inc
    tempbyte var byte
    redled		var PORTD.1
    ;----Change back to low speed for bootloader at reset
    @  ReadConfig?CB  _CONFIG1L, _tempbyte    ; Read  CONFIG1L
    tempbyte.0=1
    tempbyte.1=1
    @  WriteConfig?CB  _CONFIG1L, _tempbyte   ; Write CONFIG1L
    @  ReadConfig?CB  _CONFIG1H, _tempbyte    ; Read  CONFIG1H
    tempbyte.1=0
    @  WriteConfig?CB  _CONFIG1H, _tempbyte   ; Write CONFIG1H
    pause 1000   ; Give bootloader time to do it's thing
    ;----Accelerate up to 48mhz for your code
    tempbyte.0=0
    tempbyte.1=0
    tempbyte.1=1
    	high redled
    	low  redled
    Default Using other than 4 and 20mhz for MCS bootloader hex
    Well, the 18F4520 is a little harder, because it has a 4x pll with no pre/post scalers. Since your only external OSC options using the MCS bootloader hex files (as is) is either 4mhz, or 20mhz, that does not help.
    So I wanted to try a 10mhz crystal. The closest I had was 8mhz. But I had some luck with that.
    Checking the difference between the two hex files (4mhz and 20mhz) using the PicKit2, there were two addresses that differed. The first one (7D06) is where the baud speed is set. For a 4mhz crystal, this should be set to 0E0C hex, with 0E as an assembly command, and the last 0C as the SPBRG setting. To change this for a 10mhz chip (without 4xpll for now), should be 0E20.
    Setting this to 0E19 was correct for my 8mhz crystal, and allowed me to use the MCS bootloader hex at 8mhz. That's promising.
    Now here is where it gets a little fuzzier. The only other address that changes from 4mhz to 20mhz is 7E70. For a 4mhz, it is set to 0F, for a 20mhz it is set to 1F. It looks like it sends this to the serial port, from what I can make out of the disassembler I used. Not sure what it does with this info.....
    I tried setting everything for 8mhz with 4xpll directly using the PicKit2, but the bootloader would not work. I have not tried doing it with run time configs. And I may well be missing a setting.
    I have a little more playing to do. Maybe you can test it running at 10mhz as a first step. If that worked, we could try to do something like I did above with the 18f4550, and switch speeds using Darrel's run time config include file.
    Walter
    Feb 2009
    Southern California
    I ran into a couple little snags when attempting your solution. the first being the melabs programmer doesn't allow directly modifying the hex file, so I had to use notepad and discovered it is all stored in Little-Endian but I actually got to remember something from college after 10 years So I think I did it correctly other than my check sum was no longer good, but hopefully it is OK.
    My second problem is my chip doesn't use config1L so I got a bunch of errors and will have to compare data sheets later to figure out what you were doing in your example. Unfortunately I need to be productive for the next few hours and will have to get into this later today. I'll let you know if I have any luck
    Thanks for your help
    David
    Hey David,
    Well I was thinking of just trying the 10mhz part first, and trying to make a 10mhz bootloader hex. Let me modify it for you, and send it your way. That will be the first step. If we can get that going, we can try to do something similar to what was done on the 18F4550, only, yes, we would have to modify the config settings to match the 18f4520.
    Walter
  1. PIC18F4680 bootloader
    By vinyl_theif in forum General
    Last Post: - 29th January 2009, 17:45
  2. 18F4550 Bootloader enter via eeprom setting
    By bradb in forum mel PIC BASIC Pro
    Last Post: - 22nd November 2008, 23:51
  3. USBDemo with Bootloader
    By vacpress in forum USB
    Last Post: - 25th January 2007, 22:29
  4. Bootloader Problems
    By rossfree in forum mel PIC BASIC Pro
    Last Post: - 11th February 2005, 17:51
  5. Replies: 3
    Last Post: - 26th January 2005, 13:41
