Bootloader For 18F4520
Results 1 to 37 of 37
    brighton
    I have these if you are interested.
    Cheers mate
    i am interested as Henrik said its the loader hex files that i can't update
    Isaac
    May 2007
    Isaac, I zipped the entire folder (all of the HEX files) and it is 113Kb. We just need to figure out how to get it to you.
    May 2007
    Isaac, e-mail sent.
    brighton
    Default Bootloader For 18F4520
    Isaac, e-mail sent.
    you r great man
    Isaac
    Feb 2009
    Southern California
    Anyone have any idea what needs to be done to modify either of the included files to run at 40 MHz instead of 4 or 20? I looked over both hex files and there are only a few lines difference between them, but I have no idea what I'm actually looking at.
    David
    Quote Originally Posted by Luckyborg View Post
    David
    MCS has not provided any source code (that I am aware of) for their bootloader, so I think it would be pretty hard to modify it to run at double the speed. If you don't mind it not working directly through the MCS interface, then you could modify the assembly source code given by the Tiny Pic Bootloader, located here: http://www.etc.ugal.ro/cchiculita/so...bootloader.htm
    And run it beside your MCS.
    .... But Maybe,
    To still use MCS's bootloader hex, you could think about switching PLL settings on the fly in your code. See: http://www.picbasic.co.uk/forum/showthread.php?t=4093
    Maybe you could set the low power interrupt to change it back to 20 mhz when it powers down? Kind of backwards, but might work.
    Walter
    Feb 2009
    Southern California
    I've looked into this a little, but as I have never used mplab and try to avoid assembly my first attempts have failed. If no one has any better ideas, I'll try to look into it more next week. Thanks for the help
    David
  1. PIC18F4680 bootloader
    By vinyl_theif in forum General
    Last Post: - 29th January 2009, 18:45
  2. 18F4550 Bootloader enter via eeprom setting
    By bradb in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2008, 00:51
  3. USBDemo with Bootloader
    By vacpress in forum USB
    Last Post: - 25th January 2007, 23:29
  4. Bootloader Problems
    By rossfree in forum mel PIC BASIC Pro
    Last Post: - 11th February 2005, 18:51
  5. Replies: 3
    Last Post: - 26th January 2005, 14:41
