Bootloader For 18F4520
Results 1 to 37 of 37
    Remember that the bootloader cannot protect your code from a reading/copying.
    Sep 2005
    Campbell, CA
    Ioannis, it is possible for your PBP application code to disable the bootloader by modifying it or erasing it. You can even change configuration registers at run time.
    You can get a pretty good level of code protection that way.
    I have military customers who want to do a code update, and when they are happy that the load went well, select a menu option. They then get code protection to the limit of what Microchip offers.
    Charles Linquist
    Hi Charles. Thanks for the post. Can you elaborate on this?
    I was pretty sure that Bootloader and Secutity don't go together.
    Sep 2005
    Campbell, CA
    I don't know about all the others, but the 18F series lets you modify FLASH at run-time. You have to first erase a block, (8-64 bytes, depending on your chip type - and you have to start at a block boundary) with the ERASECODE command. After erasure, you can write whatever you want.
    I did this in several versions or "levels". This is the lowest level.
    The following to allow the bootloader to run (or not) depending on a program variable. If you set PROTECT and called PatchLoader, the bootloader will not run. If in the program, you set PROTECT = 0, and run it, the bootloader will again work.
    It should be noted that this was used with PBP 250a and an 18F8722 and MCLOADER.
    PBP2.50a could not access the upper half of the big chips (>64K) memory using READCODE,WRITECODE or ERASECODE, so I had to modify PBPPPIC18.LIB to include a new SYSTEM variable called UPMEM. The library modification set TBLPTRU to UPMEM at the beginning of these 3 routines, and cleared UPMEM at the end (so as not to screw up PBP). By setting UPMEM to 1, I could read the upper half of memory (and by setting it to 0x30, you can set/read the configuration registers). You will see that I need to set upmem before each operation to get to that upper half of FLASH. You wouldn't have to deal with that in a smaller chip.
    I have done quite a bit of this, let me know if you need any more help.
    PatchLoader:
              UPMEM = 0
             ERASECODE $0
             WRITECODE $0,$EFE0          ; Change the initial jump vector
             WRITECODE $2,$F0FF          ; 0X1FFC0
             WRITECODE $4,$FFFF
             WRITECODE $6,$FFFF
             for xx = $8 TO $3E STEP 2    ; Do the rest of the block
             WRITECODE XX,$FFFF
             NEXT Xx
             PAUSE 100
             PROTECT = 1
             GOSUB PROTECT_UNPROTECT
    PROTECT_UNPROTECT:
             UPMEM = 1
             ERASECODE $FFC0
             UPMEM = 1
             WRITECODE $FFC0,$6B08
             UPMEM = 1
             WRITECODE $FFC2,$0000
             UPMEM = 1
             WRITECODE $FFC4,$0000
             UPMEM = 1
             WRITECODE $FFC6,$0000
             UPMEM = 1
             WRITECODE $FFC8,$3F08
             UPMEM = 1
             WRITECODE $FFCA,$D7FB
           if PROTECT = 0 THEN
                 UPMEM = 1
                 WRITECODE $FFCC,$EF82
                 UPMEM = 1
                 WRITECODE $FFCE,$F0FE    ; JUMP TO 1FD04
                 UPMEM = 1
                 WRITECODE $FFCC,$EF78
                 UPMEM = 1
                 WRITECODE $FFCE,$F0FE    ; JUMP TO 1fcF0
           FOR XX = $FFD0 TO $FFFE STEP 2
                 UPMEM = 1
                 WRITECODE XX,$FFFF
           NEXT XX
    REPROTECT:
             UPMEM = 1
             READCODE $FFCC,X
               IF X = $82 THEN
                HSEROUT [13,10,10,"Reprotecting Loader",13,10]
                PROTECT = 1
    GetTypeLoader:
             READCODE 0,TypeLoader
    Charles Linquist
    Many thanks for the post.
    I will do some testing.
    brighton
    it looks like Mecanique wont support the 18f4520 as they never got back to
    me.
    Did anyone get the boot loaded from Mecanique ?
    Just really want to know
    Isaac
    Quote Originally Posted by isaac View Post
    me.
    Isaac
    OK, I originally posted away from my computer. My MCS has the 18F4520_20.hex file in it. I have MCS version 3.0.0.5. Which version do you have?
    I have just tried the 18F2520_20.hex file, and got it to work. (I don't have a 18F4520 to try).
    You should be able to update MCS over the internet. Not sure if that would update your .hex files, but I don't see why not.
  1. PIC18F4680 bootloader
    By vinyl_theif in forum General
    Last Post: - 29th January 2009, 18:45
  2. 18F4550 Bootloader enter via eeprom setting
    By bradb in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2008, 00:51
  3. USBDemo with Bootloader
    By vacpress in forum USB
    Last Post: - 25th January 2007, 23:29
  4. Bootloader Problems
    By rossfree in forum mel PIC BASIC Pro
    Last Post: - 11th February 2005, 18:51
  5. Replies: 3
    Last Post: - 26th January 2005, 14:41
