debug timeout issue 12F683
Results 1 to 8 of 8
    I made the changes to the oscillator configuration. I set up a I/O toggle with 100ms pause and I am seeing the correct timing of the test code. since the pause command derrives it's timing from the osc, I am assume it is running at 8Mhz. modified code below.
    INCLUDE "Modedefs.Bas"
    DEFINE OSC 8
    @ DEVICE PIC12F683, MCLR_OFF,INTRC_OSC_NOCLKOUT,protect_off
    DEFINE DEBUGIN_REG GPIO ' Set as software RX in
    DEFINE DEBUG_BAUD 2400 ' Set bit rate
    DEFINE DEBUGIN_BIT 0 ' Set GPIO bit 0
    DEFINE DEBUGIN_MODE 1 ' Set Debugin mode: 0 = true, 1 = inverted
    OSCCON = %01110001 ' set internal 8MHz
    TRISIO = %00000001
    ANSEL = %00000000
    ADCON0 = 0
    CMCON0 = 7 ' Disable comparator
    VRCON = 0 ' CVreff = OFF
    CCP1CON = %00001100 ' PWM mode
    PR2 = 249 '
    T2CON = %00000100 ' Start Timer2, Prescaller 1:1
    Rudder VAR byte
    Duty VAR WORD
    PWM_ON CON %00001100
    PWM_OFF CON 0
    test:
    GPIO.4 = 1
    GPIO.4 = 0
    goto test
    OSCCON = %01110001 should get you running at 8MHz internal, but you might want to
    change to DEFINE DEBUGIN_MODE 0 ' for true mode. Most IR modules idle high. Inverted
    mode serial inputs should idle low.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Talking
    Bruce, that did it. The debugin time out was being hosed by the pull up on the IR data out. Thanks for the help!!!!
    Nick
    Glad I could help. Wait until the new 8-pin 12F1822s' come out. Then you can use the
    hardware USART to receive IR data in the background using DT_INTs....
    -Bruce
    tech at rentron.com
  1. N-Bit_MATH
    Last Post: - 16th December 2010, 15:48
  2. About USB
    By dias11 in forum mel PIC BASIC Pro
    Last Post: - 3rd December 2009, 21:41
  3. debug not working with MPASM assempler
    By santamaria in forum mel PIC BASIC Pro
    Last Post: - 4th March 2009, 08:51
  4. Data EEPROM gets clobbered during programming
    Last Post: - 18th July 2008, 03:46
  5. 18F1320 ... Strange Memory
    By Acetronics2 in forum mel PIC BASIC Pro
    Last Post: - 9th April 2006, 10:55
