debug timeout issue 12F683
Results 1 to 8 of 8
    Hi Nick,
    DEFINE OSC 8 with it running on the default 4MHz internal would definitely do it.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    I made the changes to the oscillator configuration. I set up a I/O toggle with 100ms pause and I am seeing the correct timing of the test code. since the pause command derrives it's timing from the osc, I am assume it is running at 8Mhz. modified code below.
    INCLUDE "Modedefs.Bas"
    DEFINE OSC 8
    @ DEVICE PIC12F683, MCLR_OFF,INTRC_OSC_NOCLKOUT,protect_off
    DEFINE DEBUGIN_REG GPIO ' Set as software RX in
    DEFINE DEBUG_BAUD 2400 ' Set bit rate
    DEFINE DEBUGIN_BIT 0 ' Set GPIO bit 0
    DEFINE DEBUGIN_MODE 1 ' Set Debugin mode: 0 = true, 1 = inverted
    OSCCON = %01110001 ' set internal 8MHz
    TRISIO = %00000001
    ANSEL = %00000000
    ADCON0 = 0
    CMCON0 = 7 ' Disable comparator
    VRCON = 0 ' CVreff = OFF
    CCP1CON = %00001100 ' PWM mode
    PR2 = 249 '
    T2CON = %00000100 ' Start Timer2, Prescaller 1:1
    Rudder VAR byte
    Duty VAR WORD
    PWM_ON CON %00001100
    PWM_OFF CON 0
    test:
    GPIO.4 = 1
    GPIO.4 = 0
    goto test
    OSCCON = %01110001 should get you running at 8MHz internal, but you might want to
    change to DEFINE DEBUGIN_MODE 0 ' for true mode. Most IR modules idle high. Inverted
    mode serial inputs should idle low.
    -Bruce
    tech at rentron.com
    Talking
    Bruce, that did it. The debugin time out was being hosed by the pull up on the IR data out. Thanks for the help!!!!
    Nick
    Glad I could help. Wait until the new 8-pin 12F1822s' come out. Then you can use the
    hardware USART to receive IR data in the background using DT_INTs....
    -Bruce
    tech at rentron.com
  1. N-Bit_MATH
    Last Post: - 16th December 2010, 15:48
  2. About USB
    By dias11 in forum mel PIC BASIC Pro
    Last Post: - 3rd December 2009, 21:41
  3. debug not working with MPASM assempler
    By santamaria in forum mel PIC BASIC Pro
    Last Post: - 4th March 2009, 08:51
  4. Data EEPROM gets clobbered during programming
    Last Post: - 18th July 2008, 03:46
  5. 18F1320 ... Strange Memory
    By Acetronics2 in forum mel PIC BASIC Pro
    Last Post: - 9th April 2006, 10:55
