debug timeout issue 12F683
Results 1 to 8 of 8
    Question debug timeout issue 12F683
    Hello,
    I can't seem to find why the debugin does not time out after 200ms and jump to a label. I can set the port in the PowerOn_init section and drop to the debugin...but never jumps to the time out label....why? code is below.
    INCLUDE "Modedefs.Bas"
    DEFINE OSC 8
    @ DEVICE PIC12F683, MCLR_OFF, HS_OSC, INTRC_OSC_NOCLKOUT,protect_off
    DEFINE DEBUGIN_REG GPIO ' Set as software RX in
    DEFINE DEBUG_BAUD 2400 ' Set bit rate
    DEFINE DEBUGIN_BIT 0 ' Set GPIO bit 0
    DEFINE DEBUGIN_MODE 1 ' Set Debugin mode: 0 = true, 1 = inverted
    TRISIO = %00000001
    ANSEL = %00000000
    ADCON0 = 0
    CMCON0 = 7 ' Disable comparator
    VRCON = 0 ' CVreff = OFF
    CCP1CON = %00001100 ' PWM mode
    PR2 = 249 '
    T2CON = %00000100 ' Start Timer2, Prescaller 1:1
    Rudder VAR byte
    Duty VAR WORD
    PWM_ON CON %00001100
    PWM_OFF CON 0
    PowerOn_init:
    GPIO = 0
    CCP1CON = PWM_OFF
    Duty = 0
    CCPR1L = Duty
    CCP1CON.5 = Duty.1
    CCP1CON.4 = Duty.0
    PAUSE 500 ' OSC settle delay
    CCP1CON = PWM_ON ' turn on motor at low speed for 500ms
    Duty = 50
    CCPR1L = Duty
    CCP1CON.5 = Duty.1
    CCP1CON.4 = Duty.0
    Duty = 0
    CCPR1L = Duty
    CCP1CON.5 = Duty.1
    CCP1CON.4 = Duty.0
    pause 50
    GPIO.4 = 1 ; set to test whether time out works for debugin.
    Start:
    debugin 200,Alloff,[wait (85), Duty, Rudder]
    If duty < 10 then ' shut down throttle if threshold is too low
    duty = 0
    CCPR1L = Duty ' PWM duty cycle
    CCP1CON.5 = Duty.1
    CCP1CON.4 = Duty.0
    If Rudder = 192 then ' 11000000 rudder left
    GPIO.5 = 1
    GPIO.5 = 0
    If Rudder = 12 then ' 00001100 rudder right
    GPIO.4 = 1
    GPIO.4 = 0
    GOTO Start
    Alloff:
    duty = 0
    CCP1CON.5 = Duty.1
    CCP1CON.4 = Duty.0
    GPIO.4 = 0
    GPIO.5 = 0
    goto start
    Most likely it's due to noise on the input pin, which resets the timeout. Are you trying to
    read data from an RF receiver?
    P.S. You can't have both HS_OSC and INTRC_OSC_NOCLKOUT, and if you're wanting to
    use the 8MHz internal, you need to write to OSCCON.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Bruce, thanks for catching that
    I am using an IR module. Very quiet, not seeing anything that would cause it to reset. I will try scoping it out on a 2 channel, 1 channel IR data out and 2nd channel I/O pin. I don't think that is the problem though.
    Nick
    Hi Nick,
    DEFINE OSC 8 with it running on the default 4MHz internal would definitely do it.
    -Bruce
    tech at rentron.com
    I made the changes to the oscillator configuration. I set up a I/O toggle with 100ms pause and I am seeing the correct timing of the test code. since the pause command derrives it's timing from the osc, I am assume it is running at 8Mhz. modified code below.
    DEFINE OSC 8
    @ DEVICE PIC12F683, MCLR_OFF,INTRC_OSC_NOCLKOUT,protect_off
    OSCCON = %01110001 ' set internal 8MHz
    TRISIO = %00000001
    ANSEL = %00000000
    ADCON0 = 0
    PR2 = 249 '
    Rudder VAR byte
    Duty VAR WORD
    PWM_OFF CON 0
    test:
    GPIO.4 = 1
    GPIO.4 = 0
    goto test
    OSCCON = %01110001 should get you running at 8MHz internal, but you might want to
    change to DEFINE DEBUGIN_MODE 0 ' for true mode. Most IR modules idle high. Inverted
    mode serial inputs should idle low.
    -Bruce
    tech at rentron.com
    Talking
    Bruce, that did it. The debugin time out was being hosed by the pull up on the IR data out. Thanks for the help!!!!
    Nick
    Glad I could help. Wait until the new 8-pin 12F1822s' come out. Then you can use the
    hardware USART to receive IR data in the background using DT_INTs....
    -Bruce
    tech at rentron.com
  1. N-Bit_MATH
    Last Post: - 16th December 2010, 15:48
  2. About USB
    By dias11 in forum mel PIC BASIC Pro
    Last Post: - 3rd December 2009, 21:41
  3. debug not working with MPASM assempler
    By santamaria in forum mel PIC BASIC Pro
    Last Post: - 4th March 2009, 08:51
  4. Data EEPROM gets clobbered during programming
    Last Post: - 18th July 2008, 03:46
  5. 18F1320 ... Strange Memory
    By Acetronics2 in forum mel PIC BASIC Pro
    Last Post: - 9th April 2006, 10:55
