F886 & pgm
Results 1 to 15 of 15
Thread: F886 & pgm
    If only RB3 causes your problem, then I suspect you're simply not getting LVP turned off.
    It would really help if you posted your code.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    You got analog all to heck on port B, shut off the comparators and don't forget anselh
    Alabama,USA
    Default Reply
    So here’s the scoop! I’ve tested this on multiple F886 and on multiple programmers with PBP2.60 and PBP2.46.
    Bruce your right!
    “If only RB3 causes your problem, then I suspect you're simply not getting LVP turned off.”
    PBP 2.60/melabs programmer 4.23
    @ DEVICE INTRC_OSC_CLKOUT,MCLR_OFF,BOD_OFF,WDT_OFF,LVP_OFF
    OSCCON=$70
    ANSEL=     $00
    ADCON0=   $00
    CM1CON0 =$00
    CM2CON0 =$00
    Program, Read Code, View – Configuration
    Low Voltage Programming --- Enabled
    Must tie RB3 to Vss ... Remove Vss on RB3 MCU stops after about 5sec.
    Digital output voltage on RA7 low
    PBP 2.46/melbas programmer 4.23
    Same code
    Low Voltage Programming --- Disabled
    No Vss needed on RB3 ... Digital output voltage on RA7 correct
    Hobbyist was near wits end! Now What?
    don't forget anselh
    I don't see anselh in your settings...
    Hmm. That is an interesting problem.
    Try this. Save the file you're compiling in your 2.60 directory with one name, and save
    a 2nd copy of the same file in your 2.46 directory with a different name.
    Compile the one with 2.60. Open it with your MeLabs programmer software, and click on
    the C radio button. You should see a screen with config settings like the one I have
    attached.
    Now open the file in your 2.46 directory, and repeat. Are config settings the same?
    -Bruce
    tech at rentron.com
    Alabama,USA
    Default Reply
    I’ve tried ANSELH=$00 with the same results. In fact BOR was also Enabled along with a few other items. It did set internal osc at 8Mhz with clockout at 2Mhz.
    I used the code file on different computers. One with 2.60 and the other with 2.46. And yes I clicked the C radio button to take a look at the Configs.
    I think I’ll try reloading 2.60 on the computer to see if there are any changes in results.
    If you're doing this on two different PCs, it may be that you just have different settings for the MeLabs programmer. Make sure you have Options >> Update Configuration From File checked on the 2.60 machine. That sounds like the problem.
    You previously programmed it with LVP_ON, and it's not updating config settings.
    -Bruce
    tech at rentron.com
    Alabama,USA
    Default Reply
    Bruce,
    I've checked both computers. Both computers were set to "Update Configuration from file". 2.46 Config default option was set to LVP_off. 2.60 was set to LVP_on. I changed that setting and recompiled with the same results, LVP is NOT turning off on 2.60.
  1. HSERIN each character cost 3 pgm words
    By boban in forum mel PIC BASIC Pro
    Last Post: - 7th April 2008, 16:49
  2. PGM for ICSP
    By dragons_fire in forum General
    Last Post: - 15th December 2007, 01:12
