Is there a faster way to compare?
Results 1 to 13 of 13
    Omaha, Nebraska USA
    Yes, I knew about the <b>* SOMETHING</B> !
    But now I have the opposite problem . . . since yours is so much faster, I would need to run it almost three times (because the variables can range from 0 to whatever SOMETHING is scaled to). Should I just run it three times in succession, or do I need to go to a WORD variable for SOMETHING? (I need to scale SOMETHING through as much of that time span as possible.)
    Russ
    N0EVC, xWB6ONT, xWN6ONT
    "Easy to use" is easy to say.
    Totally Lost me on that one.
    Omaha, Nebraska USA
    Okay, let me background this first.
    For each of 5 channels: A 0-5V value is read (derived from an op-amp) by an ADC channel (presently at 10 bits, so 0-1023). That value is manipulated depending on other data (an offset or a correction, for example). The complementary value (1023-value), scaled so that 0 (1023-1023) can be managed in x repetitions (the maximum that can be fit into about 7.8ms) of the loop, is how long the delay in the interrupt handler must be before turning on the corresponding output pin to a triac driver. Normally, a 5us pulse would be adequate to keep the triac on until the end of the AC phase, but the indicator for the channel is an LED, so the pin is left high until the end of the phase.
    Just sending a pulse on a pin means running the FOR . . . NEXT loop only up to the scaled value and sending the pulse; keeping the indicator on proportionately (well, somewhat) means the pin must stay high until near the end of the phase.
    Your code running to 255 and finishing in 2.6ms means that only 36 percent of the 7.8ms period is controlled, because it is so fast. Proportionately, the phase would have to be scaled something like 0-765, probably a little less.
    Could I just run additional cycles of the tests before incrementing the INDEX to stretch it out?
    The code works as is, but over a very limited signal range.
    Russ
    I have not tested the idea.
    Instead of writing each IF-THEN test to the port, writing to a variable and at the end that variable to the port will be faster?
    Aug 2005
    Michigan, USA
    Hi Russ,
    Have you considered using timer derived periodic interrupts and performing just one PWM "step" per interrupt? Perhaps spreading out 256 "steps" across the 8.333-msec period (8333-usecs/256 = 32.55-usec interrupts)?
    Here's another method like Darrel's which would work well if you group the outputs consecutively (B7..B3 or B4..B0 for example). Updating the port from a 'shadow' register allows precise bit update timing (multiple bits with same duty cycle value will update at exactly the same time).
    Regards, Mike
    ;  1/256th step, 18 cycles (isochronous), active high output
    ;  on duty cycle match until end-of-period
            clrf    shadow          ; clear 'shadow'                  |B0
            movf    led+4,W         ; led[4] duty cycle, 0..255       |B0
            subwf   dcy,W           ; C = led[4] >= dcy               |B0
            rlf     shadow,F        ;                                 |B0
            movf    led+3,W         ; led[3] duty cycle, 0..255       |B0
            subwf   dcy,W           ; C = led[3] >= dcy               |B0
            rlf     shadow,F        ;                                 |B0
            movf    led+2,W         ; led[2] duty cycle, 0..255       |B0
            subwf   dcy,W           ; C = led[2] >= dcy               |B0
            rlf     shadow,F        ;                                 |B0
            movf    led+1,W         ; led[1] duty cycle, 0..255       |B0
            subwf   dcy,W           ; C = led[1] >= dcy               |B0
            rrf     shadow,F        ;                                 |B0
            movf    led+0,W         ; led[0] duty cycle, 0..255       |B0
            subwf   dcy,W           ; C = led[0] >= dcy               |B0
            rlf     shadow,W        ; W = led 'step' output           |B0
            movwf   PORTB           ; update LEDs                     |B0
            incf    dcy,F           ; bump duty cycle counter         |B0
    Omaha, Nebraska USA
    Thanks, Ioannis and Mike. Let me noodle with your suggestions for a bit.
    Meanwhile, for anyone interested:
    For an IF A [comparison] B THEN statement, without the appended action, the execution time at 8MHz if A and B are WORDs appears to be about 22-24us; if A and B are BYTEs, it appears to be about 5-6us. These numbers are not down to a gnat's whisker; they are as measured on my scope (Tektronix 465M).
    Russ
  1. How to compare strings/array? RFID Project
    By dan-tron in forum mel PIC BASIC Pro
    Last Post: - 10th April 2017, 07:21
  2. how to compare data
    By Mus.me in forum mel PIC BASIC Pro
    Last Post: - 1st November 2009, 22:30
  3. Compare Data
    By Pesticida in forum mel PIC BASIC Pro
    Last Post: - 14th February 2008, 20:40
  4. 12F675 compare voltage help.
    By geckogrotto in forum mel PIC BASIC Pro
    Last Post: - 2nd February 2007, 16:46
  5. OT - Firefox browser - faster performance
    By malc-c in forum Off Topic
    Last Post: - 14th August 2006, 10:33
