Universal remote and Rs232
Results 1 to 9 of 9
    what I mean is the "learning" function on these remotes.
    Hi Michael,
    I've never tried a learning remote with serial IR data before, but I would be interested
    in knowing if it worked or not. Could make for some really interesting projects.
    Just don't have a learning remote to test.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Bruce,and Michael, You can use any Pic micro with a pwm output to generate modulated serial data. I have been doing it for about 2 years since I started using 16F88's for remote controls. All you need are 2 diodes with there anodes connected 1 to the tx output and 1 to the pwm output and the cathodes driving a pnp transistor for the IR drive... Try it...
    Hi Dave,
    Thanks. I've done a lot of IR apps with/without external components. Except for the IR LED
    and resistor of course.
    I just worked up the Data Signal Modulator example while playing with the new 16F1827.
    The DSM module on this thing goes well beyond simple modulated IR communications. And
    a single resistor + IR LED is all you need to setup an IR wireless network with multiple PICs
    all using the hardware USART with HSERIN/HSEROUT.
    -Bruce
    tech at rentron.com
    Dec 2005
    Learning remotes do no decoding but merely record an image of the signal for playback. The source of the learned signal should not matter.
    Cool -- that's what I needed to know.
    And your right Bruce, that could make for some (very) interesting ideas.
    Be fun to even add a PIC Ired rcvr to the serial port and maybe write some VBnet stuff.
    For now though, just on/off control of my media PC with the Harmony.
  1. Replies: 17
    Last Post: - 12th April 2014, 02:17
  2. Infrared Communications over RS232 UART or with B0 interupt
    By modifyit in forum mel PIC BASIC Pro
    Last Post: - 9th December 2005, 19:17
