DC to AC convertor
Results 1 to 12 of 12
    Jun 2007
    Mansfield, UK
    Unfortunately i dont know much about the motor. I tried searching google for its number but i didnt find anything useful.
    Heres what it says on the label:-
    41TYZ-A synchronous motor
    AC 6V 50/60Hz 1.5/2W
    5r/min Cw/CCw
    California, USA
    Ahhh. It's a synchronous motor, so it not only wants AC, but it wants AC at 50/60 Hz and it probably wants at least a modest approximation of a sine wave. A square wave will probably make it unhappy...
    Is efficiency a big issue? Gonna plug it into the wall, or run it off a battery?
    If efficiency isn't really an issue, then a hardware solution with an op-amp based sinewave generator feeding an audio amplifier type driver is probably easiest.
    steve
    Jun 2007
    Mansfield, UK
    Im not too bothered about efficiency. It will be run from a mains transformer but the 12V DC needs to be turned on/off using a transistor and the motor will be connected with 64 LEDs (on the DC side). I can use a more powerfull transistor than normal but i dont want it to be using too much current.
    Ill have a look for op-amp sinewave circuits. Ive not done much with op-amps before so this is the perfect learning opportunity
    Wink Kiss ...
    An OPA triangle generator with clamping diodes on the output, plus a bridge audio amp ( TDA2005 i.e ) could produce an acceptable waveform ...
    "Sine" generator is not so difficult to build nor ...
    don't you think ???
    California, USA
    Op-amp sine generators are easy to build. A google search will get you lots of hits. Here's a couple of pages to start:
    http://www.ti.com/sc/docs/apps/msp/j...000/aug_07.pdf
    http://www.national.com/nationaledge/jun04/article.html
    Drive a TDA2005 or similar like Alain suggested and you're done...
    steve
    Jun 2007
    Mansfield, UK
    That looks easy enough. Ill add the parts to my next order and see how it goes. Thanks
  1. 600w dc to ac invertor
    By marsh in forum Forum Requests
    Last Post: - 16th August 2008, 17:04
  2. Circuit Diagram for interfacing AC to PIC IC?
    By wellyboot in forum Schematics
    Last Post: - 8th March 2008, 19:40
  3. DC - AC Solid State Relay
    By shahidali55 in forum General
    Last Post: - 10th November 2007, 16:01
  4. Special Offer AC -AC adapter
    By lester in forum Adverts
    Last Post: - 9th September 2005, 07:52
  5. AC and DC how to?
    By Scott in forum Schematics
    Last Post: - 12th August 2005, 15:21
