DC to AC convertor
Results 1 to 12 of 12
    Quote Originally Posted by The Master View Post
    I had an idea involving a 555, transistors and diodes that i think will work. The problem with that method is that i get a square wave instead of the normal AC sine wave. Would that matter to an AC motor?
    I think motors complain voiceferously to square waves, but a 555 can output various waveforms with a little work, I am pretty sure they brew up function generators using them. http://www.physics.udel.edu/~nowak/p...imer%20lab.pdf
    http://www.simplecircuitdiagram.com/...-using-555-ic/
    Why not use a PIC ? You are already good at them, yes?
    Oh here is a circuit you might glean some use from project 100 watt . . . http://datasheetreference.com/2n3055-datasheet.html
    swap out the transformer for the voltage you want, scale it down, in terms of power used / produced
    Jun 2007
    Mansfield, UK
    I could use a PIC but im not sure why. Wouldnt that just turn things on/off to generate an AC output? That would result in a square wave too.
    Thanks for the links. Ill have a read through them.
    California, USA
    A 6VAC motor? What frequency does it want?
    Is it really AC only, or is it a "universal" motor that runs on AC or DC? Does it have brushes?
    Building a converter to drive it should be easy enough, but I'd be curious to know more about the specifics of the motor first.
    steve
    Jun 2007
    Mansfield, UK
    Unfortunately i dont know much about the motor. I tried searching google for its number but i didnt find anything useful.
    Heres what it says on the label:-
    41TYZ-A synchronous motor
    AC 6V 50/60Hz 1.5/2W
    5r/min Cw/CCw
    California, USA
    Ahhh. It's a synchronous motor, so it not only wants AC, but it wants AC at 50/60 Hz and it probably wants at least a modest approximation of a sine wave. A square wave will probably make it unhappy...
    Is efficiency a big issue? Gonna plug it into the wall, or run it off a battery?
    If efficiency isn't really an issue, then a hardware solution with an op-amp based sinewave generator feeding an audio amplifier type driver is probably easiest.
    steve
    Jun 2007
    Mansfield, UK
    Im not too bothered about efficiency. It will be run from a mains transformer but the 12V DC needs to be turned on/off using a transistor and the motor will be connected with 64 LEDs (on the DC side). I can use a more powerfull transistor than normal but i dont want it to be using too much current.
    Ill have a look for op-amp sinewave circuits. Ive not done much with op-amps before so this is the perfect learning opportunity
    Wink Kiss ...
    An OPA triangle generator with clamping diodes on the output, plus a bridge audio amp ( TDA2005 i.e ) could produce an acceptable waveform ...
    "Sine" generator is not so difficult to build nor ...
    don't you think ???
    California, USA
    Op-amp sine generators are easy to build. A google search will get you lots of hits. Here's a couple of pages to start:
    http://www.ti.com/sc/docs/apps/msp/j...000/aug_07.pdf
    http://www.national.com/nationaledge/jun04/article.html
    Drive a TDA2005 or similar like Alain suggested and you're done...
    steve
  1. 600w dc to ac invertor
    By marsh in forum Forum Requests
    Last Post: - 16th August 2008, 17:04
  2. Circuit Diagram for interfacing AC to PIC IC?
    By wellyboot in forum Schematics
    Last Post: - 8th March 2008, 19:40
  3. DC - AC Solid State Relay
    By shahidali55 in forum General
    Last Post: - 10th November 2007, 16:01
  4. Special Offer AC -AC adapter
    By lester in forum Adverts
    Last Post: - 9th September 2005, 07:52
  5. AC and DC how to?
    By Scott in forum Schematics
    Last Post: - 12th August 2005, 15:21
