RTC module - Easypic5
Results 1 to 12 of 12
    What is a RTC2 ?
    Dave,
    Here's a link to the RTC2: http://www.mikroe.com/en/tools/rtc2-proto/
    Malc-c,
    You can use this with pretty much any pin that I2CWrite/I2CRead work on, and
    you can probably find several PBP examples here for working with the DS1307.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Thanks Bruce,
    I was going to suggest what you did but though maybe it was something special.
    Just a regular RTC...
    I use the 1337 on a 4550 with pins PORTD.0 and PORTD.1.
    For whatever it is worth....
    Hey Dave,
    Yeah - it's just a plain-old DS1307.....)
    Malc-C,
    Here's one of the best examples I've ever seen for PBP using the DS1307 by Melanie;
    http://www.melabs.com/resources/samp...ted/MN1307.txt
    I suspect the reason they recommend specific pins was due to them using hardware I2C
    in the sample code they provide for the RTC module.
    -Bruce
    tech at rentron.com
    May 2007
    I suspect the reason they recommend specific pins was due to them using hardware I2C in the sample code they provide for the RTC module.
    That is correct.
    malc-c's Avatar
    malc-c Guest
    Thanks once again for all the input.
    I'll take a look at those examples. I've not used any I2C device before so forgive me for these noobie questions - and Reading TFM just confused things
    True, especially since you're using a complete module. If you were using a plain RTC chip, I'd suggest choosing 2 pins which are weak pull-up capable, the'd save you 2 external resistors on the signal lines.
    Anand
    malc-c's Avatar
    malc-c Guest
    Default pin outs
    Quick question, I'm having problems reading the schematic of the board http://www.mikroe.com/pdf/rtc2_schematic_v100.pdf
    The board doesn't have the 3 x 2 header shown, just the 5 x 2 which connects to the easypic5. As I need to breadboard these modules to connect to the spare pins I'll have and not take up a full port can some one tell me what pins on the 5 x 2 header I need to connect to the PIC (other than supply )
    EDIT: - just looked at the code and previous replies... RC3 and RC3 are suggested, so that would be pins 4 and 5 on the header
    May 2007
    One possibility to consider. If you do not need all the features of a full-blown RTCC (especially the calendar and alarm), you can implement a real time clock on a PIC18 with just a watch crystal and 2 capacitors - less than $0.30 in cost.
    Using the Secondary Oscillator (RC0, RC1, and TIMER1), all it needs is just a few lines of code to implement an interrupt driven real time clock. Look at the data sheet section for TIMER1 for more details.
  1. Version Control
    Last Post: - 16th October 2011, 17:12
  2. Replies: 1
    Last Post: - 27th July 2008, 06:14
  3. Oscillator stops when touching with a wire
    By Wilbert Ingels in forum mel PIC BASIC Pro
    Last Post: - 25th April 2008, 08:51
  4. PIC 16F877 I2C communications
    By sigmoideng in forum General
    Last Post: - 13th July 2007, 10:28
  5. X1226 RTC - Help
    By charudatt in forum mel PIC BASIC Pro
    Last Post: - 14th August 2006, 17:54
