changing osc on the fly
Results 1 to 23 of 23
    Art, What would you use as a reference in that situation?
    If you have a PIC that supports Internal/External Oscillator Switchover then you shouldn't need a firmware solution to determine osc speed. You already know what it should be after you write to OSCCON & flip the System Clock Select bit.
    If you have one running on the internal oscillator, and you need to calibrate it, then Microchip has a few app notes for this using TMR1 with an external 32.768kHz watch type crystal. Or you could just output the internal clock on OSC2/CLKO and test it with an O-scope.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
  1. Define osc 1
    By ronsimpson in forum mel PIC BASIC Pro
    Last Post: - 1st October 2009, 06:35
  2. Changing bits in a byte for multiple output
    By tazntex in forum Serial
    Last Post: - 11th August 2008, 19:10
  3. Replies: 4
    Last Post: - 16th May 2008, 14:35
  4. Changing declared variables names on the fly
    Last Post: - 16th December 2006, 06:34
  5. Mode changing on the fly
    By Angus Anderson in forum GSM
    Last Post: - 28th November 2006, 08:58
