changing osc on the fly
Results 1 to 23 of 23
    It is poor engineering practice to operate a device outside of the manufacturer's specs - take a look at the graph above where it shows that the minimum voltage is 4.2V for frequencies >25Mhz.
    But I am not an engineer
    I look at the graph as showing the primary frequency.
    I have not built anything to run on less than 3.3 volts. I do a lot at 3.3 though. Have for some time. Makes working with SD cards and other low power things much easier. One power supply.
    May 2007
    Makes sense then.
    Sep 2005
    Campbell, CA
    If you need to run at 4Mhz on the internal OSC, put this in your code.
           movlw 0x62                              ; %0110 0010  = 4 Mhz, internal osc block
           movwf OSCCON
           movlw 0x80                              ; %1000 0000  = PLL disabled
           movwf OSCTUNE
    I have a development board that runs at 40Mhz on a 10Mhz XTAL + PLL, but sometimes I need to slow things down to 4Mhz and run on the internal oscillator to see how they will run on "little" parts. This code does the trick.
    Charles Linquist
    Aug 2003
    I was thinking of a routine that could detect the clock speed the pic is running at
    so that then the pic program could adjust serial speed, etc accordingly.
    Make a delay loop in picbasic and count the number of ticks a hardware timer
    makes during the delay loop.. and then the hardware timer value will be
    different for different clock speeds.
    May 2007
    Wouldn't a delay need to know clock speed to work correctly?
    Art, What would you use as a reference in that situation?
    If you have a PIC that supports Internal/External Oscillator Switchover then you shouldn't need a firmware solution to determine osc speed. You already know what it should be after you write to OSCCON & flip the System Clock Select bit.
    If you have one running on the internal oscillator, and you need to calibrate it, then Microchip has a few app notes for this using TMR1 with an external 32.768kHz watch type crystal. Or you could just output the internal clock on OSC2/CLKO and test it with an O-scope.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Aug 2003
    No, because you use a timer based on RC clock, which is always the same,
    but the delay is dependent on osc speed.
    So, start timer, execute delay, read timer.
    The fact that the delay varies is what I'm counting on.
    May 2007
    Lets say you have a 4MHz clock and you set a delay of 1mS (1000us). A timer (without pre/post scaler) will count to 1000 for the duration of the delay.
    Now drop the clock the 1MHz. The timer will now count to 250 (1000/4) each mS. However, the delay will increase to 4mS due to the slower clock, so the timer will again count to 1000.
  1. Define osc 1
    By ronsimpson in forum mel PIC BASIC Pro
    Last Post: - 1st October 2009, 07:35
  2. Changing bits in a byte for multiple output
    By tazntex in forum Serial
    Last Post: - 11th August 2008, 20:10
  3. Replies: 4
    Last Post: - 16th May 2008, 15:35
  4. Changing declared variables names on the fly
    Last Post: - 16th December 2006, 07:34
  5. Mode changing on the fly
    By Angus Anderson in forum GSM
    Last Post: - 28th November 2006, 09:58
