changing osc on the fly
Results 1 to 23 of 23
    I may be wrong on this but...
    Power consumption is relative to voltage. Clock speed is relative to voltage.
    Faster the clock, higher the voltage.
    But with this type of PIC it will run at 2 volts with a 4MHz external.
    So, using the PLL the PIC can "virtually" run at 48MHz on 2 volts and not consume extra power.
    I run this PIC at 3.3 volts and 48MHz but I have not measured the amps...
    Sep 2007
    USA, CA
    That is all true... but you will save even more power by putting the pic to sleep. A a high speed pic that is sleeping most of the time will draw less power than a 4mhz pic awake all the time.
    May 2007
    ....Clock speed is relative to voltage.
    Not quite. There are minimum voltages required to run at specific frequencies but there is not a direct relationship between the 2.
    ....Power consumption is relative to voltage.
    You cannot run it at 48Mhz with a 2V supply. With a PIC18F4550 supply current can range from 0.8mA (4MHz INTRC, 2.0V) to as high as 50mA (48MHz EC, 5.0V), a range of more than 62:1 - see section 28.2 DC Characteristics: Power-Down and Supply Current of the data sheet.
    Using one of the Power Managed (idle/sleep) modes is the proper way to go. See Section 3.0.
    OK. Not a direct relationship. I should have said clock speed and minimum voltatge.
    Maybe not at 2 volts, but 2.5 is doable. Using the PICKIT2 for a PS, only goes down to 2.5. So I can not verify the 2 volts right now...
    May 2007
    ...Maybe not at 2 volts, but 2.5 is doable. Using the PICKIT2 for a PS, only goes down to 2.5. So I can not verify the 2 volts right now...
    It is poor engineering practice to operate a device outside of the manufacturer's specs - take a look at the graph above where it shows that the minimum voltage is 4.2V for frequencies >25Mhz.
    But I am not an engineer
    I look at the graph as showing the primary frequency.
    I have not built anything to run on less than 3.3 volts. I do a lot at 3.3 though. Have for some time. Makes working with SD cards and other low power things much easier. One power supply.
    May 2007
    Makes sense then.
    Sep 2005
    Campbell, CA
    If you need to run at 4Mhz on the internal OSC, put this in your code.
           movlw 0x62                              ; %0110 0010  = 4 Mhz, internal osc block
           movwf OSCCON
           movlw 0x80                              ; %1000 0000  = PLL disabled
           movwf OSCTUNE
    I have a development board that runs at 40Mhz on a 10Mhz XTAL + PLL, but sometimes I need to slow things down to 4Mhz and run on the internal oscillator to see how they will run on "little" parts. This code does the trick.
    Charles Linquist
  1. Define osc 1
    By ronsimpson in forum mel PIC BASIC Pro
    Last Post: - 1st October 2009, 07:35
  2. Changing bits in a byte for multiple output
    By tazntex in forum Serial
    Last Post: - 11th August 2008, 20:10
  3. Replies: 4
    Last Post: - 16th May 2008, 15:35
  4. Changing declared variables names on the fly
    Last Post: - 16th December 2006, 07:34
  5. Mode changing on the fly
    By Angus Anderson in forum GSM
    Last Post: - 28th November 2006, 09:58
