Stupid simple question.....
Results 1 to 19 of 19
    Jun 2008
    Default Stupid simple question.....
    I'm trying to make a button work...
    here is my test code:
    input Pin4
    loop:
    if Pin4 = 1 then cycle
    goto loop
    cycle:
    if Pin4 = 0 then loop
    high 0 : pause 100
    high 1 : pause 100
    high 2 : pause 100
    low 0 : pause 100
    low 1 : pause 100
    low 2 : pause 100
    goto cycle
    When I connect pin4 to high nothing happens... Do I need to pull the pin high or low or something? Should I have something other than the "input Pin4" command?
    This seems like it should be super fricking simple, but it just doesn't work... I feel like I'm taking crazy pills!! Someone please help.
    www.theLanguageBear.com - Multi-Lingual books for kids and adults of all skill levels.
    Pin4 is usually PORTB.4, and not actually Pin4 on the chip.
    Which chip are you using?
    Jun 2008
    I'm using a 12F683, GP4 (which I believe is the same as PORTB.4?) is Pin3.
    Jun 2008
    I could use some help here... I am completely at a loss. I can't get any input to work at all, am I going crazy?
    For a 12F683, you need to turn off the Analog inputs and Comparator.
    SYMBOL ANSEL = $9F
    SYMBOL CMCON0 = $19
    POKE ANSEL, 0
    POKE CMCON0, 7
    hth,
    Jun 2008
    I cannot express enough gratitude. It works! Thank you so much kind sir. Now where might one learn a bit of information like that? That seems fairly basic, but I don't recall coming across that in any of my "pic'n" books or the 12F datasheet...
    If you look at section 4 in the datasheet you'll see a note there saying:
    Note: The ANSEL and CMCON0 registers must be initialized to configure an analog channel as a digital input. Pins configured as analog inputs will read ‘0’.
    There's also an example showing how to do it but it's in ASM so it's not that easy to understand.
    If you then look at figure 8.4 you'll see the various configurations for the comparator module and in the bottom right hand corner it shows that you should write 7 (the three lower bits are set) to CMCON0 in order to disable the comparator.
    If you then look at the bottom of table 2.2 it'll show you that ANSEL "comes up" with the lower 4 bits set and if you look at register 4-3 (page 33) you'll see that when bit 0-3 is set it means that the pin is in "analog mode".
    As for the rest, $9F is the adress for ANSEL register and $19 is the adress for the CMCON0 register and that can be found if you look at figure 2.2 in the same datasheet. PBP makes it a lot easier as it allows you to write directly the the registers without having to look up the actual adress of it "manually".
    It's a very common thing to overlook untill you've been bitten by it, next time a pin doesn't work as you think it should it'll be the first thing you'll think of checking ;-)
    Jun 2008
    oy...
    Thanks guys, you rock..
    How I wish I could be using my Arduino for this project..
    Jun 2008
    Default Another dumb ass problem
    I really hate this stuff.... it makes me want to stab myself in the eyeball with a fork.
    I'm measuring 3v from Pin1 (GP1) on my 12F683.
    I'm using a 3v coin cell. It measures 3v.
    I connect a LED to Pin1, it lights.
    YAY! Next frickin challenge....
    I connect a small vibe motor to my 3v battery, it vibrates like crazy. Yay.
    I connect my small vibe motor to Pin1 (measuring 3v) It does absolutely nothing.
    I connect the LED to Pin1.. it lights..
    I connect the motor to Pin1 ... it does nothing
    I punch stuff... that doesn't help.
    I don't know what else to try...
    The vibe motor draws about 35-40mA
    I see that the IO pins supply 25 mA but the GPIO can supply 90mA...
    What's the difference?
    Quote Originally Posted by chien_fu View Post
    A single pin can put out a max of 25mA, but the entire GPIO (all output pins) can put out a max of 90mA. You could use a transistor, or you could have two pins control the motor (and hope start current would not be too high).
    Jun 2008
    So I tried driving it with two pins but something else is screwy now....
    This is what I have:
    OUTPUT Pin1
    output Pin2
    Startup:
    for startupalarm = 1 to 4
    high 2
    high 1
    pause 5000
    low 2
    low 1
    pause 5000
    next startupalarm
    It seems that "high 2" does not actually switch the pin high, but just ticks it high for a split second. "high 1" switches the pin high and it is held high for 5 seconds until it is switched low...
    This is the same regardless of which pins I use. The line of code immediately preceding the pause command works, all others do not. Nothing else is connected to the chip, it's all by itself on a breadboard.............
    You're suffering from what is called a RMW problem (read-modify-write). The way the PIC works when setting a single bit in a register, like the GPIO-port in this case, is to first read the whole register, then set the bit in question and finally writing the whole register "back".
    Because your motor presents a large a load to the pin (especially at startup) the voltage on the pin will sag or be low. So what is happening is this:
    First you have the High 2. This reads the port (as a byte), sets bit 2 and writes the whole byte back to the port.
    Now you have High 1 which does the same thing but because pin2 is heavily loaded it will read as 0 when the port is read, the PIC then sets bit1 and write back to the port resulting in bit 2 now being reset to 0.
    The best bet is to use a transistor to drive the motor. If that's not an option then write to the port directly, setting both pins at the same time. You do this in the same way as Darrel showed you how to write to CMCON etc - look up the physical adress of GPIO and use POKE to write to it.
    Remember also, you must treat your Motor as an INDUCTOR or RELAY. The back emf could destroy your PIC pin or Transistor switching it. Put that all important Diode reverse-biased across the Motor.
    Post
    +1 .....
    Good answer from Henrik ...
    Last edited by Acetronics2; - 23rd February 2010 at 09:44. Reason: I must RTFM !!!
    Nah, if you look at section 9.1 of the mid-range manual you'll find the following:
    All write operations (such as BSF and BCF instructions) are read-modify-write operations. Therefore a write to a port implies that the port pins are read, this value is modified, and then written to the port data latch.
    So I'll stick to my theory ;-)
    Talking
    Ok Henrik ...
    One red tomato for me ... ( was the question ...)
    this also explains why it acts the same whith heavy capacitive loads ... driving directly Big Mosfets gates i.e.
    PS: but what an Idea µChip had to proceed like that ???
    Jun 2008
    Why is it that when I enter:
    GPIO = %11111111
    Picbasic says "Undefined variable"?
    Because the variable GPIO isn't defined....
    This is because you're using PBC and it doesn't provide a way to directly write to the registers as you're trying to do - only PBP does that. As I wrote in my previous message you need to do as Darrel showed you earlier in the thread:
    SYMBOL GPIO = $05     '$05 is derived from the memory map in the datasheet for 12F683
    SYMBOL TRISIO = $85
    Poke TRISIO, 0   'Set all available GPIO pins as outputs
    Poke GPIO, 255  'All availble GPIO pins high.
    Jun 2008
    Cool, thanks.
  1. Really simple question for you experts :)
    By lew247 in forum mel PIC BASIC Pro
    Last Post: - 4th June 2008, 02:43
  2. SIMPLE question
    Last Post: - 5th February 2008, 19:27
  3. Stupid question
    By Meriachee in forum mel PIC BASIC Pro
    Last Post: - 20th July 2007, 06:47
  4. really simple, dumb question
    By picster in forum mel PIC BASIC Pro
    Last Post: - 3rd March 2007, 23:02
  5. really simple adcin question
    By kitcat in forum mel PIC BASIC Pro
    Last Post: - 21st April 2006, 10:06
