Beginer problems
Results 1 to 8 of 8
    Jan 2010
    Default Beginer problems
    Hi!
    I just started to explore Microchip PIC and I have a huge problem.
    I am very satisfactory with writing code in PicBasic, to simulate different schematics in Proteus, to program different microchip pic (12F629, 16F628) with a JDM programmer and verify, but my problem is that when I make the schematic on a breadboard (solderless board) nothing works!
    I used a 9V battery, ULN7805+10uF+0.1uF, a 12F629 (and later 16F628) and tried to flash a led on one microcontroller pin + 330 ohmi resistor.
    Do you know what can be wrong?
    The microcontroller seems to be well programed (and verified), the power supply is stable, same schematic works well in proteus (and many more other schematics with microcontrollers) ...
    The JDM programmer was bought from a local store...
    I don't use any anti-static tools.
    Thank you very much!
    Wink
    Hi, Luxor
    Welcome aboard the Forum !
    Could you post here one of the codes you tried ???
    Will be much, much, much simpler to find what you've forgotten ...
    Jan 2010
    Default This is my code and schematics
    ' LED FLASHING PROGRAM
    ' This program flashes an LED connected to port RB0 of PORTB. The
    ' LED is flashed with 1 second intervals.
    LED VAR PORTB.0 ' Define RB0 as LED
    ' START OF MAIN PROGRAM
    TRISB = 0 ' Set PORTB pins as outputs
    AGAIN:
    LED = 1 ' Turn ON LED
    PAUSE 1000 ' Wait 1 second
    LED = 0 ' Turn OFF LED
    GOTO AGAIN ' Repeat forever
    END ' End of program
    Lightbulb
    Ok Luxor
    Bingo : You simply forgot to write the chip A/D relevant registers config and define I/Os for your chip ...
    DEFINE OSC 4             ' Default Osc freq
    DEFINE OSCCAL_1K 1   ' retrive the trimming value
    CMCON		= 7 ' disable Analog comparators
    GPIO 		= %00000000 'All pins LOW at startup
    TRISIO 		=%00101000  'set GPIO3 & GPIO5 as inputs
    so, add those lines to the top of code.
    AND do not forget to connect the RESET PIN ...
    a look to the 629 Datasheet will help !
    Jan 2010
    Default Thank you very much for your help
    I'l try as soon as possible.
    Thanks again.
    Jan 2010
    Default At last, the project is finished
    I had many problem and brain damage because I used MPASM as assembler instead of PM.EXE (I used MicroCode Studio too). Simply line like
    @ device  pic16F628, intrc_osc_noclkout
    gave me strange error codes...
    But now, the project is working. I hope somebody find it useful.
    Thanks all of you for help.
    ' PIC16F628 20I/P
    ' Pic Basic Pro Compiler 2.45, (c) 1998, 2004 microEngineering Labs, Inc.
    ' Assembler used is PM.EXE, provided with microEngineering Labs PICBasic Compiler
    INCLUDE "modedefs.bas"
    @ device  pic16F628, intrc_osc_noclkout; Use internal oscilator
    @ DEVICE pic16F628, MCLR_OFF ; Turn off internal reset (default) and leave RA.5 as an input
    CMCON     = 7          ' PortA = digital I/O
    VRCON     = 0          ' A/D Voltage reference disabled
    TRISB     = %00000000  ' PORTB all pins outputs
    ' Define RB0 as LED (pin number 6):
    LED VAR PORTB.0
    ' VSS - pin number 5  (Ground)
    ' VDD - pin number 14 (+5V)
    ' MCLR (pin number 4) pulled-up to VDD by 4.7Ko resistor
    'program start
    AGAIN:
    Wink
    Hi,Luxor
    I see on your listing you missed that :
    http://www.melabs.com/downloads/P245A1.EXE
    this is an official patch for your PBP 2.45 version ...
  1. Problems with U2 programmer C30 compiled code
    By minimii in forum Off Topic
    Last Post: - 5th November 2009, 09:43
  2. Problems programming
    By Lionheart in forum General
    Last Post: - 7th December 2008, 16:51
  3. 2 PWM in 16F690 problems
    By ciendavila in forum mel PIC BASIC
    Last Post: - 27th April 2008, 09:03
  4. HSEROUT Problems
    By SergioRM in forum mel PIC BASIC Pro
    Last Post: - 7th April 2005, 23:17
  5. USART problems
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 6th March 2005, 21:45
