Simple Blinking LED - WTF!!
Results 1 to 6 of 6
    Default Simple Blinking LED - WTF!!
    OK, I've been out of the PIC stuff for about a year now and have noticed some significant brain drain (on my behalf)
    I am just trying to get back into the PICbasic with some simple LED blinking with a 12F683. I looked at some of my old code with controlled 3 LED's and the code (compiled) works just fine. But when I comment out 2 of the 3 LED's, the remaining LED just stays ON.
    The code posted shows only GPIO.1 remaining active...but the LED stays on.
    I know this is peanuts to all of you...but please help me out. I even tried a simple code with a simple loop! Still didn't work.
    John.
    osccon = %01100000  ' Ocs set to 4 MHz
    trisio = %00000000  '
    wpu = %00011000
    'CMCON0 = 7                ' Analog comparators off
    'ANSEL  = 0                ' Analog select set to digital, pg 69 data
    'ADCON0 = 0                ' A/D turned OFF, pg 68 of data
    pausetime var word
    Out0 	var gpio.0
    Out1 	var gpio.1
    Out2 	var gpio.2
    B0		var	byte
    ' SET VARIABLES
    	pausetime = 200
    	B0 = 0
    	low 0
    	low 1
    	low 2
    start:
    'button gpio.3,1,10,5,B0,1,notp
    if gpio.3 = 1 then goto start
    'call blink0
    'call blink2
    call blink1
    goto start
    blink0:
    high out0
    pause pausetime
    low out0
    'pause pausetime
    blink1:
    high out1
    pause pausetime
    low out1
    'pause pausetime
    blink2:
    high out2
    pause pausetime
    low out2
    'pause pausetime
    notp:
    goto start
    Hi johnnylynx,
    Change CALL to GoSub
    Call is an asm function - return works with gosub.
    Hi johnnylynx,
    Thanks for the quick feedback - Question though - why would it work if all three or two CALL lines are active?
    I tried changing the CALL to GOSUB and it still didn't work. If I add a 'PAUSE pausetime' after the LOW command it worked. Found that solution elsewhere!
    Why would it work with out the added PAUSE (with 2 or more CALL's active)?
    Confused I am.
    John.
    Quote Originally Posted by johnnylynx View Post
    Confused I am.
    John.
    Hi John,
    Think about what you are telling it to do,
    Turn light on
    pause 200
    turn light off
    no waiting here
    turn light on
    pause . . . The PIC is faster than the eye.
    Hi John,
    Turn light on
    pause 200
    turn light off
    no waiting here
    turn light on
    Yep, time for me to get some rest...Can't believe I missed that. Now I can rest peacefully.
    Thanks!
    Jan 2010
    Don't feel bad, I looked over it and didn't see that either! haha.
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 07:14
  2. Free Project - 245 LED Display
    Last Post: - 16th August 2009, 05:59
  3. 20 Mhz Crystal, simple blinking LED
    By BenjaminsShinob in forum mel PIC BASIC Pro
    Last Post: - 16th October 2007, 06:06
  4. LCD will not start
  5. simple LED Blinking project
    Last Post: - 11th December 2004, 02:25
