12F683 2 x PWM Outputs
Results 1 to 30 of 30
    Quote Originally Posted by retepsnikrep View Post
    Thanks for the reply. I do plan on doing something with this in due course.
    Great confidence I have now ... NOT!
    Oh well, more things to do tomorrow I have ....
    Tonight, I do this ...
    Next year, you may try it.
    DEFINE OSC 8
    SPWMpin  var GPIO.5     ' Output Pin for SSPWM
    INCLUDE "SSPWM.inc"     ' include the SSPWM module
    ;----[Constants]------------------------------------------
    HPWMfreq        CON 20000
    Freq = 2000             ' Set Frequency of SSPWM (word)
    ;----[Variables]------------------------------------------
    HPWMduty        VAR BYTE
    LastHPWMduty    VAR BYTE
    SSPWMduty       VAR BYTE
    ;----[Initialize]-----------------------------------------
    OSCCON = %01110000      ' 8Mhz
    ANSEL = %000011         ' AN0 and AN1 ANALOG
    DutyCycle = 10          ' Set Duty Cycle of SSPWM
    gosub StartSPWM         ' Start SSPWM @ Freq/DutyCycle
    HPWM 1, 127, HPWMfreq   ' Start 20Khz PWM @ 50%
    ;----[Main Program Loop]---------------------------------
        ADCIN 0, HPWMduty
        ADCIN 1, SSPWMduty
        IF HPWMDuty != LastHPWMduty THEN
            LastHPWMduty = HPWMDuty
            HPWM 1, HPWMDuty, HPWMfreq
        DutyCycle = SSPWMduty*80/256+10  ' scale SSPWM dutycycle
        gosub SetSPWM                    ' Change SSPWM DutyCycle
    GOTO Main
    Dutycycle of the 2Khz is 10% in the image.
    Both dutycycles are adjustable from the pots, and works from 10% to 90%, (0 to 100% for the HPWM).
    Don't forget to comment the wsave vars not used by the 683 in the .inc file.
    Happy Holidays.
    Incredible I was envisaging pages of code! many thanks to Darrel
    Could you post that Isis code and hex code as i have it and would like to look at the simulation.
    Could you post that Isis code and hex code...
    Here ya go.
    Darrel
    Can you tell me the version of issis/proteus you are using i can't load it, my version is 7.4 SP2
    Cheers
    7.8 SP0 (beta)
    If your license is up to date, you should be able to run the update manager and get the latest version.
    Back to breadboard then it will cost be a fortune to upgrade suffciently to run it. Thanks anyway.
    I only have the picaxe VSM lite software which doesnt support simulating plain pics etc anyway.
    Talking Thanks
    Thanks to all those who helped with this i have had this breadboarded and working in my pic on bench today, it works great. What a forum incredible. Now to design my pcb.
  1. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 07:03
  2. 2 PWM in 16F690 problems
    By ciendavila in forum mel PIC BASIC
    Last Post: - 27th April 2008, 10:03
  3. 12f683 comparator and pwm
    By Automan in forum mel PIC BASIC Pro
    Last Post: - 23rd May 2007, 19:05
  5. Variable PWM on 2 Channels using software.
    Last Post: - 23rd September 2006, 02:34
