12F683 2 x PWM Outputs
Results 1 to 30 of 30
    Default Re: 12F683 2 x PWM Outputs
    Just like DT's interrupt routines, you some times need to comment out a few lines in the include file
    Look inside "SSPWM.inc"
    ' --- IF any of these three lines cause an error ??  Simply Comment them out to fix the problem ----
    wsave1      var byte    $A0     SYSTEM          ' location for W if in bank1
    wsave2      var byte    $120    SYSTEM          ' location for W if in bank2
    wsave3      var byte    $1A0    SYSTEM          ' location for W if in bank3
    Nov 2011
    Thank you very much Mark.
  1. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 06:03
  2. 2 PWM in 16F690 problems
    By ciendavila in forum mel PIC BASIC
    Last Post: - 27th April 2008, 09:03
  3. 12f683 comparator and pwm
    By Automan in forum mel PIC BASIC Pro
    Last Post: - 23rd May 2007, 18:05
  5. Variable PWM on 2 Channels using software.
    Last Post: - 23rd September 2006, 01:34
