Mystery Compile Error
Results 1 to 16 of 16
    I'm running Windows XP SP3 and PBP 2.6 with MCS 3.0.0.5
    The code is this:
    DEFINE OSC 20
    FLASH_RATE VAR BYTE
    LED_0 VAR PORTB.0
    FLASH_ON = 1500
    FLASH_OFF = 500
    lblLoop:
    High LED_0
    Pause FLASH_ON
    Low LED_0
    Pause FLASH_OFF
    GoTo lblLoop
    Again, this worked on my old PC with a previous version of PBP.
    Also, if I try to compile one of the sample files from c:\pbp\samples (e.g. adcin3x) I get tons of these errors:
    Error c:\pbp\pbppic14.lib 272 : [225] Undefined Symbol 'PORTE'
    That is starting to sound like the wrong PIC is selected???
    I thought so too, but I'm doing a compile only - not programming the chip. I tried selecting the PIC that I wrote that code for (12f629) but it still showed the same error.
    Now I am confused. What PIC and what code?
    The 12F629 does not have a PORTB or E if you are referring to the code in post #4.
    Use GPI0.x
    Sorry, it was other code for the 12f629 I was thinking of - this code was written for my test PIC, 16f84a.
    Quote Originally Posted by RossWaddell View Post
    The 16F84A does not have an E port.
    You may want to post the whole code and the configs and maybe a screen shot of how the code editor is set.
    You have to compile for the correct PIC and re-do the code to match.
    I installed PBP 2.60 & MCS 3.0.0.5 on my laptop and this code works (selecting 16f84a):
    DEFINE OSC 20
    FLASH_ON VAR BYTE
    FLASH_OFF VAR BYTE
    LED_0 VAR PORTB.0
    FLASH_ON = 1500
    FLASH_OFF = 500
    lblLoop:
    High LED_0
    Pause FLASH_ON
    Low LED_0
    Pause FLASH_OFF
    GoTo lblLoop
    I tried bumping up the memory allocation for the Windows XP virtual machine that is reporting the out of memory error, but no luck.
    What is the parent OS?
    This may help
    http://www.picbasic.co.uk/forum/showthread.php?t=12532
    It's an iMac with Mac Snow Leopard OS (10.6.2). I'm using Parallels Desktop to create the Windows XP virtual machine.
  1. 16F877A Microcode Studio won't compile
    By curt66111 in forum mel PIC BASIC Pro
    Last Post: - 25th November 2009, 20:35
  2. Loop with two motor and 2 sensors
  3. Optimizing DIV
    Last Post: - 22nd September 2008, 05:58
  4. 18F452 compile error
    By Woodzy in forum mel PIC BASIC Pro
    Last Post: - 10th November 2006, 17:56
  5. 16F88 Compile error
    By Toley00 in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2005, 01:22
