DT_INTs with 16F690
Results 1 to 4 of 4
    Thanks for the upgrade info.... version 1.00 now in place.
    I need the Change on Port A function, so RAC_INT is it. Will check the data sheet on how to enable IOAC.
    Quote Originally Posted by Dick Ivers View Post
    I think with RAC_INT, you do not need to select IOAC, or IOAB bit. You only need to when using RABC_INT (which you might think of as an AorB_INT).
  1. HSERIN / SERIN Problem with 16f690
    By rborsuk in forum Serial
    Last Post: - 5th February 2010, 04:51
  2. 16f690 crashes
    By Lincoln S. in forum Serial
    Last Post: - 26th November 2008, 08:32
  3. Using HPWM in half bridge mode on 16f690
    By Chris Barron in forum mel PIC BASIC
    Last Post: - 29th December 2006, 11:18
  4. PBP & 16F690 bug?
    By Ron Marcus in forum mel PIC BASIC Pro
    Last Post: - 29th May 2006, 23:18
  5. 16F690 Support
    By Ruben Pena in forum mel PIC BASIC Pro
    Last Post: - 5th September 2005, 22:35
