 Originally Posted by
tekart
				Had a long chat with Charles at MElabs and he had me go over all the hardware and also try DEBUGIN.  Still not recognizing the qualifier
 Hello Guy,
Your code works for me, even with hex. (at least on my 12f683). But, I have to add this at the top of my code. Otherwise, I get no response.
	CMCON0 = 7              'TURN COMPARITORS OFF
ANSEL  = %00000000      'Set all pins to digital I/O
ADCON0 = %00000000      'Analog converter OFF
 Here's what I used for my 12f683:
	define OSC 8
OSCCON = %01110000      'set for 8mhz internal
ANSEL  = %00000000      'Set all pins to digital I/O *wont work without this *
'*  uC      : PIC12F508                                         *
' chip setup
'	oscillator = INTRC
'	watchdog = enabled
'	MCLR = INPUT
	X 	var 	byte			' dummy variable
'	************** DEBUGIN SETUP ************
	define debugin_bit 1		' incoming data bit
	define debug_baud 9600		' baud
	define debugin_mode 0		' 0 = true
' Pin Assignments
	SCADAin		var gpio.1		' data in via MAX232
	Ready		var gpio.2		' signal main processor to send data
                                'I changed from gpio.4 to match my hardware
	low ready	' set low
' config
	TRISIO = %000010		' set I/O directions (0 = output, 1 = input)
	'OPTION_REG = %01011111	' 12F508/9  bit 6 disables weak pull-ups
        OPTION_REG = %01000010	' for my 12f683
'	while scadain = 1 : wend	' test code detects presence of serial burst
'	debugin 200,Noop,[wait(120)]	' wait for address and command
	serin scadain,2,400,noop,[$0F]	' check for right qualifiers only
	pause 10		' wait for serial burst to end
	high Ready	' signal main processor to send current data
	pause 2		' with a 2mS pulse
	low ready
NoOp:
