pic 12F683 question
Results 1 to 8 of 8
    Jan 2010
    Belgium Taviers 5310
    Default Frozen pins
    I tested and the
    use of "include "bs2defs.bas"" did not bring live to the pins.
    Some other idea.?
    Now that I look at the data sheet I see GPIO.4 is analog.
    So add
    ANSEL = 0
    Near the beginning of your code. That will make all pins digital.
    Other than that I do not see a problem.
    How are your configs set and how is it wired?
    Jan 2010
    Default Ansel = 0
    Thanks Dave for your anwer.
    But " ANSEL = 0 " did not bring a amelioration.
    Regards.
    Bouif2
    Yes ...
    a ( working ...) typical 12F683 INTOSC Header ...
    @ __config _INTRC_OSC_NOCLKOUT &_FCMEN_OFF &_IESO_OFF & _WDT_ON &_PWRTE_ON & _MCLRE_OFF & _CP_OFF
     OSCCON = %01110111					' Internal Clock 8 Mhz
     CMCON0 = 7
     VRCON   = 0
     ADCON0 = 0
     ANSEL   = 0
    and NO "Define Osccal" to write ...
    You have [no]some[/no] LOTS OF good reading to do, this evening ... BEFORE sleeping.
  1. MXcom "C-BUS" interface to PIC question
    By tcbcats in forum mel PIC BASIC Pro
    Last Post: - 1st May 2014, 03:59
  2. Pic Interference and Power Filter Question
    By Hylan in forum General
    Last Post: - 24th January 2008, 07:50
  3. Remote PIC input question
    By Adrian in forum mel PIC BASIC Pro
    Last Post: - 1st September 2007, 15:44
  4. 12F683 battery powered remote - energy consumption question
    By silentwol in forum mel PIC BASIC Pro
    Last Post: - 13th April 2007, 13:23
