Low freq PWM problem
Results 1 to 6 of 6
Threaded View
    Apr 2006
    GearSweaterMountain, The Netherlands
    Default Low freq PWM problem
    Hi All,
    I'm kind of stuck at the moment.
    I need a pwm signal with a low frequency. Darrel has made the awesome slow pwm module but i can't use because i need timer1 to do a continues pulse count. So i'm trying to code my own, but i can't seem to figure it out.
    I'm using timer0 to to make the frequency, with Darrels DT_INTS-14. This works perfect. Preloading timer0 with 190 give about 118Hz where i need 120Hz so thats ok. On every interrupt the PORTC.0 pin is made high.
    I'm using timer2 to make the dutycycle. I thought if i have a frequency of 120Hz the period is about 8333uS. If i need 256 dutycycle steps i need a interrupt at 8333uS/256 steps = 32,6uS. Timer2 is setup (presc. 1:1, postsc. 1:1, pr2=64) to generate an interrupt every 32,5uS.
    If i need a 50% dutycycle, simply count 128x timer2 interrupts and that make the output low. Could be quite simple I thought, but i was wrong. On my scope i see a nice 117Hz stable signal with a dutycycle of 1 or so. If i alter the dutycycle var i sometimes see a dutycycle that ramps down at every cycle ?
    Here's my code :
    '==== Set fuses =========================================
    'Fuse are set in .inc file
    '==== Set includes ======================================
    INCLUDE "DT_INTS-14.bas"                                'DTints Interrupt System
    include "ReEnterPBP.bas"                                'Enable PBP int reenter
    '==== Dec's for OSC =====================================
    DEFINE OSC 8                                            'Int OSC @ 8 MHz, for PBP
    OSCCON = %01110001                                      'Int OSC @ 8 MHz
    '==== Set defines =======================================
    OPTION_REG  = %00000111                                 'Set TMR0 precsaler to 1:256, source Fosc/4
    WPU         = %00000000                                 'Weak pull-ups disabled
    INTCON      = %11100000                                 'Global + Perhip. INT enabled, TMR0 int enabled
    PIE1        = %00000010                                 'TMR2 to PR2 match INT enabled
    PIE2        = %00000000                                 'Set TMR1 overflow interrupt
    PIR1        = %00000000
    PIR2        = %00000000
    PCON        = %00000000
    IOC         = %00000000                                 'Interrupt On Change disabled
    PCON        = %00000000                                 'Ultra lowpower + BOR disabled
    ANSEL       = %00000000                                 'Select analog inputs: none
    ANSELH      = %00000000                                 'Select analog inputs: none
    ADCON0      = %00000000                                 'A/D Module is OFF
    ADCON1      = %00000000                                 'A/D control register
    CM1CON0     = %00000000                                 'Comparator1 Module is OFF
    CM2CON0     = %00000000                                 'Comparator2 Module is OFF
    VRCON       = %00000000                                 'Voltage ref. disabled
    TRISA       = %00000000                                 'Set Input/Output (0 to 5)
    PORTA       = %00000000                                 'Ports High/Low (0 to 5)
    TRISB       = %00000000                                 'Set Input/Output (4 to 7)
    PORTB       = %00000000                                 'Ports High/Low (4 to 7)
    TRISC       = %00000000                                 'Set Input/Output (0 to 7)
    PORTC       = %00000000                                 'Ports High/Low (0 to 7)
    T2CON       = %00000100                                 'Timer2 is On,
    T1CON       = %00000000                                 'Timer1 is off
    CCP1CON     = %00000000                                 'CCP engine is off
    '==== Set Constants =====================================
    'none
    '==== Setup DTints interrupt handler ====================
    INT_LIST  macro                                         ;Setup IntSource
            INT_Handler    TMR0_INT,  _intTMR0,  PBP,  yes  ;Enable TMR0 interrupts
            INT_Handler    TMR2_INT,  _intTMR2,  PBP,  yes  ;Enable TMR0 interrupts
        INT_CREATE                                          ;Create interrupt processor
    '==== Dec's for pin aliasing INPUT'S ====================
    'none
    '==== Dec's for pin aliasing OUTPUT'S ===================
    gi1 var PORTC.0                                         'Injector 1 output pin
    '==== Dec's for variables ===============================
    dutycycle var byte                                      'Holds the needed dutycycle
    dutycount var byte                                      'Counter for dutycycle
    '==== Initialise variables ==============================
    gistate   = 0
    dutycycle = 0
    dutycount = 0
    '==== Wait for hardware settle ==========================
    '==== Enable interrupt processing =======================
    TMR0 = 190                                              'Preload Timer0 for interrupt @ 120Hz
    PR2 = 64                                                'Preload PR2 for dutycycle interrupt
    dutycycle = 128                                         'Set duty cycle to 50%
    @   INT_ENABLE   TMR0_INT                               ;Activate TMR0 INT
    @   INT_ENABLE   TMR2_INT                               ;Activate TMR2 INT
    '==== Main program loop =================================
    @   nop                                                 ;Do nothing
    '==== The End ===========================================
    theend:                                                 ' Endless loop
    goto theend                                             ' Endless loop
    'Routines and Handlers
    '==== TMR0 Interrupt handler ============================
    intTMR0:                                                'TMR0 INTERRUPT HANDLER
    TMR0 = 190                                          'Reload TMR0
    gi1 = 1                                                 'Activate injector 2
    @ INT_RETURN                                            ;Jump back to previous process
    '==== TMR2 Interrupt handler ============================
    intTMR2:                                                'TMR0 INTERRUPT HANDLER
    PR2 = 64                                                'Reload PR2
    if dutycount = dutycycle then                           'If dutycycle is met,
        gi1 = 0                                             'Deactivate injector 1
        dutycount = 0                                       'Reset the dutycounter
        dutycount = dutycount + 1                           'Add 1 to dutycounter
    Anyone have an idea ?
    Best regards, UB
  1. Old and beyond help ?
    Last Post: - 11th December 2008, 15:23
  2. confused problem with interrupt in a working program
    By illuminator4 in forum mel PIC BASIC Pro
    Last Post: - 14th November 2008, 17:01
  3. problem with PWM
    By mimmmis in forum mel PIC BASIC Pro
    Last Post: - 12th September 2008, 13:36
  5. 4-line LCD Help - using PortA instead of B
    Last Post: - 31st March 2005, 03:14
