RGB Fading Using 3 LEDs and PWM
Results 1 to 28 of 28
    The best way to learn, is to place the program on a PIC and see what's happen with. Try to modify it and see how it affect different parts. You can't blow anything. The worst situation will be 'syntax error' or something like that.
    JDM160's Avatar
    JDM160 Guest
    Quote Originally Posted by mister_e
    Yea, I know! My stuff is in the mail though.. doh! And I really am trying to understand how this program works. It does independantly vary the duty cycle of the different colors right? HOW!?!
    I really appreciate your time - I can't wait to get my PICs.
    JDM160's Avatar
    JDM160 Guest
    Eureka!
    I got it!
    ledPWM:
    For y = 0 to 2
    Select Case y
    Case 0
    pwm red, rbgarray[y], 1
    case 1
    pwm green, rbgarray[y], 1
    case 2
    pwm blue, rbgarray[y], 1
    end select
    I was having trouble realizing that the nested Case statement in the For statement was hitting "red" with rbgarray[1], "green" with rbgarray[2] and "blue" with rbgarray[3] - which are each different values between 1-256!
    It's like the sun rising, in my mind..
    Feb 2005
    Essex, UK
    Although this sequence works reasonably well. Why do the LEDs when they have faded to OFF remain slightly lit when realy they should be OFF?
    Also, during the sequence, one LED jumps quickly to another, I have it when BLUE goes OFF, it jumps to RED quickly, then goes OFF again. Are others getting the same, it is quite quick.
    Is there any other RGB sequences out there that perform a similar task??
    Cheers,
    i think it's more a math calculation overflow... try to do some simple calculation when 'rainbowval' is reaching something like 200,230,240... or lower. if you have ICD capability it's easy to see whats happen. MicroCode free version have ICD for 16F628.
    See Bruce's website Here for the ICD explanation
    Here to buy full version or to download free version Of MicroCode Studio
    it's worth every $ you'll place on this program.
  1. RGB Fading Using 3 LEDs and PWM
    By _abello in forum mel PIC BASIC Pro
    Last Post: - 19th April 2006, 15:50
  2. Slowing Down RGB PWM Routine
    Last Post: - 8th March 2005, 09:22
  3. Tidying Up PWM Routine
    Last Post: - 21st February 2005, 00:26
  4. PWM conflict
    By Srigopal007 in forum mel PIC BASIC Pro
    Last Post: - 1st September 2004, 15:18
  5. pics with 3 hardware PWM ports
    By CBUK in forum mel PIC BASIC Pro
    Last Post: - 5th August 2004, 00:14
