DT-INTs What's legal in an INT handler?
Results 1 to 14 of 14
    Dec 2008
    Los Angeles, CA
    Default DT-INTs What's legal in an INT handler?
    My program spends most of it's time in a loop waiting for an interrupt (button presses). Once received, I need to decode 24 buttons and execute the right commands.
    My present interrupt handler has a SELECT CASE function in it, with a GOSUB in every case to execute the functions. Is this legit? What are the specifics and restrictions in an interrupt handler?
    With DT_INTS using a PBP type interrupt, pretty much anything goes. I.E. use as many
    PBP instructions as you like in the int handler.
    That's the really cool part of using DTs' int program. He's done all the work for you.
    Just don't GOSUB outside the interrupt handler - or it will go-like-splat...
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Dec 2008
    Los Angeles, CA
    Thanks Bruce. The issue that led me to this question is obviously something else.
    I'm using LONG variables for the first time, and have an issue where a bit in a 24-bit LONG is being changed/corrupted by me TOGGLEING another, unrelated BIT variable! I figured the problem is me MISDECLARING my variables OR my interrupt handler. Bit 14 of the LONG variable GRN is being corrupted when I toggle the bit variable SOLO. (If I don't use interrupts, the problem goes away).
    My variable declarations are:
    RED         VAR     LONG
    GRN         VAR     LONG
    BUTTONS     VAR     LONG
    X           VAR     LONG
    Y           VAR     BYTE
    Z           VAR     BYTE
    RED0        VAR     RED.BYTE0
    RED1        VAR     RED.BYTE1
    RED2        VAR     RED.BYTE2
    GRN0        VAR     GRN.BYTE0
    GRN1        VAR     GRN.BYTE1
    GRN2        VAR     GRN.BYTE2
    BU0         VAR     BUTTONS.BYTE0
    BU1         VAR     BUTTONS.BYTE1
    BU2         VAR     BUTTONS.BYTE2
    LCD         VAR     BYTE[80]
    COUNTER     VAR     BYTE
    VOL         VAR     BYTE
    SOLO        VAR     BIT
    Thanks.
    Sep 2005
    Campbell, CA
    Bruce, could you please explain your comment to me? I would think that PBP knows what bank it is in, and keeps track of that - even in an interrupt handler. Is that not true?
    And what constitutes "outside the interrupt handler"? Must all the handler code be placed between the INT entry point and the INT_RETURN?
    I have to admit, I have violated your "rule" and it hasn't caused problems. Am I lucky?
    Please explain.
    Charles Linquist
    ? toggle command is only good for port pins ?
    Dec 2008
    Los Angeles, CA
    Smile
    Oh my gosh, you're right! I don't know why I thought that would work for a bit. That fixed it.
    THANKS Michael.
    Please explain.
    __________________
    Charles Linquist
    Hi Charles,
    Would be happy to answer if you could point me to the inital post...
    -Bruce
    tech at rentron.com
    Sep 2005
    Campbell, CA
    This is a cut-and-paste from post #2 above.
    __________________
    Charles Linquist
    Dec 2008
    Los Angeles, CA
    I wanted to clarify a point just to possibly help somebody else...
    Unfortunately, TOGGLE does work to change the state of a BIT variable, even though this is an incorrect use of the command! It also quite possibly clobbers some other unsuspecting variable, in this case a LONG. It would be nice if the compiler would flag it, but it doesn't so BEWARE!!
    Thanks again, Michael.
    Hi Charles,
    What I meant was -- you don't want to jump outside an interrupt handler routine - without
    returning to it.
    I.E. if you GOSUB outside the interrupt routine, and don't re-enter it before your return, you might
    experience major problems.
    DT_INTS needs to exit from DT_INTS. If you jump outside of this routine, and try to return
    from the interrupt on-your-own, you're going to have a problem.
    Exit from an interruppt requires a lot of regitsers to be restored.
    If you jump outside of the int routine, and return on-your-own, you will for sure see a problem.
    -Bruce
    tech at rentron.com
    May 2008
    Italy
    ------------ DT Interrupt handler --------
    Get_Byte:
    do something here
    If black then gosub apples
    If withe then gosub peach
    @ return
    apples:
    do something
    peach:
    do something
    Bruce, can you please explain better your statement? from what you said, I understand that the above example code could give problems, while I am using this type of jump out of the interrupt handler, quite often and I never experienced any problem.
    Al.
    Hi Al,
    No problem at all with your code. You GOSUB outside the int handler, and you RETURN right back to it, so this isn't a problem.
    The problem is only when you GOTO (or GOSUB) to another routine, outside an interrupt handler, and you do NOT return to it where it restores saved registers, and issues a RETFIE command.
    You show a DT Interrupt handler. You may not see it, but i guarantee theres a lot of code on exit from a DT interrupt routine
    that's restoring system file registers.
    -Bruce
    tech at rentron.com
    Sep 2005
    Campbell, CA
    I feel better now! I haven't broken any laws.
    Charles Linquist
    May 2008
    Italy
    Bruce, tank you for the explanation.
    Al.
  1. DT instant int error
    By mel4853 in forum mel PIC BASIC Pro
    Last Post: - 17th January 2010, 16:12
  2. Quick thoughts: DT Ints with encoders
    Last Post: - 7th January 2010, 01:01
  3. DT Ints work around for IOCA Register?
    Last Post: - 6th January 2010, 01:20
  4. Problem with Dt Ints Interrupts
    By Quin in forum mel PIC BASIC Pro
    Last Post: - 18th July 2008, 19:21
  5. Replies: 1
    Last Post: - 2nd November 2006, 23:24
