Problem driving lcd from PIckit2 and 16F887
Results 1 to 6 of 6
    Dec 2009
    Default Problem driving lcd from PIckit2 and 16F887
    Recently bought Sandhu book on programming the 16F877A and trying to adapt programs to run on the 16F887 which appears pretty similar but am having problems. Nothing but black squares on the lcd. I have entered and run a simple program to switch on each LED on port D in sequence which works OK. The simpler program (below) is supposed to flash the LED on portD bit 0 which it does but also switches on permanently all the other LEDs on portD.
    [CLEAR ; clear memory locations
    DEFINE OSC 4; Osc speed
    LOOP: ; main loop
    HIGHPORTD.0 ; turns LED connected to D0 on
    PAUSE500 ; delay 0.5 seconds
    LOWPORTD.0 ; turns LED connected to D0 off
    GOTO LOOP; go back to Loop and repeat operation
    END; all programs must end with END
    The program which is supposed to operate the LCD is as follows:
    [CLEAR; Define LCD registers and control bits
    DEFINE OSC 4; Osc speed]
    DEFINE LCD_DREG PORTD; data register]
    DEFINE LCD_RSREG PORTE ; select register ]
    DEFINE LCD_RSBIT 0 ; select bit] These Defines
    DEFINE LCD_EREG PORTE; enable register] are all explained
    DEFINE LCD_EBIT 1 ; enable bit] in the PBP
    DEFINE LCD_RWREG PORTE ; read/write register] manual.
    DEFINE LCD_RWBIT 2 ; read/write bit]
    DEFINE LCD_BITS 8 ; width of data path] Can be 4
    DEFINE LCD_LINES 2 ; lines in display]
    DEFINE LCD_COMMANDUS 2000 ; delay in micro seconds]
    DEFINE LCD_DATAUS 50 ; delay in micro seconds]
    ; Set the port directions. We are setting (must set) all of PORTD and all of PORTE as outputs
    ; even though PORTE has only 3 lines. The other 5 lines will be ignored by the system.
    TRISD = %00000000; set all PORTD lines to output
    TRISE = %00000000; set all PORTE lines to output
    ; Set the Analog to Digital control register
    ADCON1=%00000111; needed for the 16F877A see notes above and below
    ; this makes all of ports A and E digital.
    LOOP:; The main loop of the program
    LCDOUT $FE, 1; clear screen, go to position 1
    PAUSE 250; pause 0.25 seconds
    LCDOUT "HELLO"; print
    LCDOUT $FE, $C0; goto second line, first position
    LCDOUT "WORLD"; print
    PAUSE 250; pause 0.25 seconds to see the display
    GOTO LOOP; repeat
    END; all programs must end in END
    This simply produces a row of black squares !
    I'm not very good at this and feel sure I am doing something daft... Any comments/help would be appreciated !
    The two PICs you mention are very different.
    The OSCs and ADC are two big ones that come to mind.
    Look at the data sheets for both and you will see.
    Then work on blinky. To start use a non analog pin just to finf out if the configs are correct.
    Dec 2009
    Thanks ... I will pour a stiff drink and study the data sheets ! I checked that both chips had an 8 bit D port and a 3 bit E port and connected the lcd to them. I first checked that I could flash LED's on the D port and that seems OK so I presume the configuration is more or less OK. I will have a look at the osc as you suggest !
    Thanks again
    Are you using the 44 pin demo board?
    Dec 2009
    Yes I am ! ...and I just chickened out .. Connected the LCD to the default pins on Ports A and B and it now works. I just have now to modify the programs that use those ports unless I can figure out why it doesnt like ports D and E . Many thanks for your input
    Port D on that board goes to the LEDs unless the jumper is removed.
