Interrupt RPM and Taylors Elapsed time on 18F4620
Results 1 to 40 of 71
Threaded View
  1. #19
    With both PICs running at 20MHz, CCPR1L & CCPR1H should have the same values - since it's all done in hardware with the capture module capturing the value of timer1 after the
    4 rising edges.
    Yes the captured value is stored in CCPR1L:H, but the CCP module does not clear Timer1. You have to do that. And it's not being cleared until after the math.
    Then it goes back up to Loop: and clears it again, without any reference to the incoming signal. (actually, it is referenced to the last capture plus math time).
    If you only clear it once, immediately after the capture, then it will be ready for the next capture.
    The first capture is always wrong, and must be discarded.
    Loop:
    TMR1H = 0    'Clear 8-bit register
    TMR1L = 0    'Clear 8-bit register
    capture = 0  'Clear Timer
    Start:
          If Capture = 0 then
             Goto Start
          T1CON.0=1
          Capture = 0
    CaptureLoop:
    If Capture = 0 then
      Goto CaptureLoop
    T1Con.0=0
    period.LowByte=CCPR1L
    period.HighByte=CCPR1H
    RPM = 10000
    RPM = RPM * RPM ' 100,000,000
    RPM = DIV32 period ' 100,000,000 / RevCount
    RPM = RPM * 60 ' Per minute
    RPM = DIV32 400
    RPM = (RPM*5)
    SEROUT2 LCD,84, [Prefix,CursorPS,20,"RPM ",dec5 RPM, " ", DEC CCPR1L, " ", dec CCPR1H]
    Gosub ClearTimer1
    Goto Loop
    Added: I guess if Timer1 was Stopped in the ClearTimer1 routine (or at Loop: ), what you have would work better, but it will only capture every other 4-pulses. (8-pulses total)
