12aBridge, What are you trying to accomplish with the statements:
lcdout $FE,1
pause 700
lcdout $FE,1,"one" 'this doesnt work
pause 700
lcdout $FE,1
pause 700
lcdout $FE,2,"two" 'this doesnt work
pause 700
lcdout $FE,1
pause 700
LCDOUt $FE,#temp 'this doesnt work
pause 700
The statement:lcdout $FE,1 will try to clear the display. Some display's require a small amount of time ~5 to 15 milliseconds before being able to receive data. You are sending the data string "one","two",and the ascii representation of the value in temp to the display before it has had a chance to execute the previous command of clear screen. After sending the clear screen command "$FE,$01" wait for about 10 milliseconds (pause 10) and see if that doesn't cure the problem... I normally wait for 100uS after I send any commands that require the use of the $FE command. especially the ones that change curcor position. If you read the data sheet for the display you are using these delays will be called out...
