16F677 lcd troubles
Results 1 to 9 of 9
    Oct 2009
    Default 16F677 lcd troubles
    hello I have a standard parallel interface lcd that I have hooked up to a 16F677
    and I cant get it to go ,I have never had trouble with these before ,I have tested the screen on a 16F84 and it works ,but will not work on the 677,
    but the controls do work ,Ie I can turn on the blinking cursor and move it around on the screen ,but as soon as i send it a character it just goes blank
    I have turned off all the hardware stuff I can find ,I have also move it around on the pic so its not a problem with one port specifically .I have it running on the internal clock ,but have tried it hooked up to a standard 4MHz crystal ,but it still does the same thing ,I have also tried defining the osc at 4MHz so the lcdout instruction knows how fast the internal osc is going but this made no difference
    I am using microcode studio 2.2.1.1 and PBP2.47 I have a epic win programmer and are currently using the melabs beta driver for it
    Any tips or suggestions would be greatly apreciated
    If it works with one PIC and not the other on the same board then it must be a code/config problem.
    Post your code and config settings from the inc file if you are not setting them in code.
    Then maybe we can help.
    Oct 2009
    sorry this took a while to get back I have been busy lately
    again any enlightenment would be great ,cause its got me beat .I should also mention its my first "project" with one of the newer pics with the internal clocks and what not,so it could be something quite obvious to you more experienced PIC'ers
    INCLUDE "modedefs.bas"
     @ device  pic16F677, intrc_osc_noclkout
    'DEFINES ------------------------------
    OSCCON = %01100101   'set internal clock at 4MHZ
    OSCTUNE = %00000
    'OSCCON = %01101000
    define OSC 4    'this makes no difference
    trisb = %00000000
    trisc = %00000000
    WPUB = %00000000   'weak pullups on portB disabled
    IOCB = %00000000  'interupt on change disabled
    SSPCON.5 = 0 'SSPEN
    CM1CON0 = %00000000 'comparaters disabled
    CM2CON0 = %00000000
    ANSEL = %00000000
    'ADON = 0 'no ADC inabled
    define LCD_DREG PORTB
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTC
    DEFINE LCD_RSBIT 7
    DEFINE LCD_EREG PORTC
    DEFINE LCD_EBIT 6
    DEFINE LCD_BITS 4
    define LCD_BITS 4
    define LCD_LINES 1
    define LCD_COMMANDUS 2000
    define LCD_DATAUS 50
    temp var byte
    'start-------------------------------------
    temp = 104
    lcdout $FE,$0E 'this works
    pause 1500
    lcdout $FE,$14 'this works
    pause 1500
    lcdout $FE,$80 'this works
    pause 1500
    Loop:
    lcdout $FE,1
    pause 700
    lcdout $FE,1,"one"  'this doesnt work
    pause 700
    lcdout $FE,1
    pause 700
    lcdout $FE,2,"two" 'this doesnt work
    pause 700
    lcdout $FE,1
    pause 700
    LCDOUt $FE,#temp 'this doesnt work
    pause 700
    goto loop
    thanks
    Shot in the dark:
    ANSELH = 0
    and take out the extra define LCD_BITS 4
    Oct 2009
    wow I dont know how many times Ive looked through that code and never spotted I had that define twice, but that didnt work ,But clearing ANSELH did thanks so much ,I have no idea why that works though but its sure good to see text on that screen
    thanks joe
    Quote Originally Posted by 12aBridge View Post
    Look at the data sheet section 4-4: There is a chart which shows ANS8:11 assignments (analog). I picked up this tidbit just last week, reading someone else's posts.
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 20:14
    Last Post: - 8th August 2009, 20:54
  3. Need help with LCD number display.
  4. LCD will not start
  5. Dedicated LCD Controller question
    By chuckles in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 15:44
