SMDs are not that bad. One or two now and then a loupe and a "pointy" iron will do. More? A toaster oven works fine.
But I am going to look at Bruce's idea. Six feet! WOW! That would be great for many things.
Bruce, thanks for the pointer; it made for some very interesting reading.
Like Dave says SIX FEET? Wow!
My requirement is to transmit just a few mm, so I'm hoping I could get away without using any extra hardware at all. The question I'm wondering about, considering the *very* modest range requirement, would I need to modulate the Debugout signal, or just feed it to the MOSFET driving the coil every few 100s of ms (the rest of the time the coil wouldkeep getting its 32 KHz for power transfer).
BTW, I had no idea of the existence of the 16F639. Sure opens up loads of possibilities!
Anand
It took a bit of experimentation to get the 6+' distance. It's all about placement of the
small RFID LF antennas on the receiving unit. Once you get that dialed-in you get a
whopping range. The first pictures were the initial prototypes. These had around 3+'
range.
This picture is the final version that works at 6+' range. If you compare placement of the
small RFID antennas on this one to the one above you'll know how/where to put them for
excellent range. You can walk up to the initiator with the ID badge in your back pocket, and
it still gets solid comms.
The final ID board is about 1/3 the size of a credit card, and modified to fit into a keychain
type plastic enclosure.
SMD caps & resistors are all 0402 size. Boy were those fun to hand-solder on the last
prototype. Phew...
I used a TC4422A high-speed MOSFET driver to drive the large LF antenna, and PWM to sendwould I need to modulate the Debugout signal
data like this;
The receiving end just uses PULSIN to grab the inbound data.Code:ID_Init: T1CON.0 = 0 ' Shut-down Timer1 during wake-up routine ' Wakeup sequence. 4mS ON, 500uS gap, 2mS ON, 2mS OFF. Then ' follow up with header & data. CCP1CON = 12 ' PWM ON PAUSEUS AGC_STABLE CCP1CON = 0 ' PWM OFF PAUSEUS GAP CCP1CON = 12 PAUSEUS 2210 ' 2mS ON CCP1CON = 0 PAUSEUS 2210 ' 2mS OFF ' Wakeup sequence complete CCP1CON = 12 ' Send header after initial wakeup PAUSE 1 ' 1mS high on receiver LFDATA pin CCP1CON = 0 PAUSEUS 500 ' header complete ' Transponder should now be waiting for data payload FOR LOOPS = 0 TO 7 ' loop for all 8-bits CCP1CON = 12 IF DAT.0[LOOPS] THEN PAUSEUS 500 ELSE PAUSEUS 250 ENDIF CCP1CON = 0 PAUSEUS 500 ' this pause allows 500uS for ID badge to respond NEXT LOOPS ' after challenge code is sent. CCP1CON = 0 ' turn off PWM ' Data payload complete PAUSE 5 ' Pause a bit so interrupt flag-bit can be set when ID badge responds TMR1L = 0 TMR1H = 0 ' Clear Timer1 count before re-enabling T1CON.0 = 1 ' Re-enable Timer1 on exit RETURN ' Notes: After wakeup the receivers 16F639 AFE inactivity ' timer will expire after 16mS. Any gap in transmision that ' exceeds 16mS will require another wakeup sequence before data ' can be sent.
Neat project! But 0402?
Do you have REALLY good eyesight or do you have really good lighting and magnification?
I'm pretty comfortable with 0603 but it's sure easy to lose those little suckers on the bench...
I'd love to see a thread with "Tips & Tricks" for dealing with SMD parts, along with suggestions and reviews of really handy tools, lighting, magnifying device, etc to make the job easier. More and more "neat new parts" are available as SMD only, and a lot of the "old familiar" through-hole parts are disappearing. SMD is a way of life now. I'd love to see a "SMD Help" category added to the forum...
steve
Stuff just wouldn't fit otherwise, and we needed the free space for the 418MHz UHF & 125kHz RFID parts. There's a UHF antenna for the Linx RF transmitter on the back of the board just behind the Primeport logo.But 0402?
These RF parts need x amount of clearance from board components, so we had to go with 0402 to squeeze everything into a keyfob enclosure on a board 1/3 the size of a credit card. The CR2032 battery holder & UHF antenna sucked-up 50% of the
board space.
The board photo looks big, but it's definitely not.
We do all SMD placement under a lab microscope, and beyond the initial prototype, we do all soldering with a RoHS comlpiant reflow oven, and lead-free solderpaste screened boards.
We use the Gold-Flow GF-B-HT reflow oven and a zoom stereo trinocular microscope mounted on a boom stand for SMD placement. Photos attached.
RF design is a whole new world, and if it's not spot-on, you ain't getting that FCC stamp of approval. So you allow for whatever clearance is needed for the RF stuff.
You don't need to sell me on the NEED for small precisely placed components! I understand why small SMD parts are desirable.
Now I'm interested in good tools and techniques to make SMD more accessible for us mere mortals.
I wanna know how us wannabees can do it most efficiently, without a HUGE expense.
Excellent! Does your microscope have a model number? Are there things you particularly like or dislike about it? Is it... horribly expensive?We do all SMD placement under a lab microscope,
These are the kind of tools I seek, but it's nice to have good reviews from folks who actually USE them, rather than blindly whipping out the credit card.
I love SMD components! But they can definitely push the limits of my eyesight and dexterity, so I'm in search of good tools and techniques to make things easier.
steve
I do not do stuff as small as Bruce and I am not building for certification....
I have a set of loupe and one of those headband magnifyers like jewelers use.
I also, do not laugh, use one of these.
http://www.intel.com/support/intelplay/qx3/
pretty much everything I do is custom, so all I have to be able to do is a good prototype.
For reflow I use a toaster oven from walmart.
That is how this newbee does it....
