camera delays
Results 1 to 5 of 5
Thread: camera delays
    Just in case your camera happens to be a Canon, there's an elegant software-only solution that would give you an intervalometer and a lot more.
    http://chdk.wikia.com/wiki/CHDK_in_Brief
    Anand
    I get these Errors in the Select Case portion of the code;
    C/pbp/pbppic14.lib 47 : [226] Numeric Constant or Symbol Name Expected
    C/pbp/pbppic14.lib 47 : [201] ‘)’ Expected
    Compiles without error here.
    Which version of PBP are you using?
    Alabama,USA
    Default Replay
    After two hours of trying to solve the compile problem (with PBP2.60) I posted my question and turned off the computer for lunch. On return I read DT's comment and tried again. This time it worked (which now concerns me). Man, Darrel your good! I have no idea what happend beside loosing two hours. I guess the hard drive has polterbytes. Thanks again guys for your comments, and yes it is a Canon. I'll give the site a look.
    Quote Originally Posted by MOUNTAIN747 View Post
    In fact, I'd urge everybody on the forum owning a Canon to check this out; its fantastic. Remote shutter control, motion detection, ultra high speed, loong exposures, time lapse, bracketing, the works. And the tool is scriptable too.
    Anand
  1. PICs can do more if use others than delays instructions
    By hardcore in forum mel PIC BASIC Pro
    Last Post: - 24th February 2010, 20:52
  2. Replies: 2
    Last Post: - 8th February 2009, 06:10
  3. Camera with PIC chip
    Last Post: - 1st July 2008, 15:28
  4. 12F629 Strange interupt behavior
    By BGreen in forum mel PIC BASIC Pro
    Last Post: - 25th May 2007, 16:35
  5. Camera interfacing PC help
    By Koraki in forum mel PIC BASIC Pro
    Last Post: - 13th September 2005, 18:49
