Interrupts 101
Results 1 to 3 of 3
Thread: Interrupts 101
Threaded View
    Oct 2009
    Default Interrupts 101
    Hello everyone. I am having a bit of a problem, this code (or it's equivalent) works merrily on assembler, but it seems to lose the declarations for the ports after if executes the interrupt routine.
    Can anyone tell me what I am doing wrong? This code works ok, but as soon as it hits the asm routine, it stops working. The interrupt works, the sequence works, values are sent to the variable portc.3 but the port does not respond. Even if I use "portc.3" instead for led4, it does not respond.
    Thanks for your help
    (at 4Mhz, there would be 234375 interrupts per minute, roughly 1500 interrupts per half a second)
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 23:14
  2. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 22:43
  3. Microcode studio - PIC16F877A Interrupts
    By mcbeasleyjr in forum mel PIC BASIC Pro
    Last Post: - 8th January 2009, 07:10
  4. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 21:48
  5. help: TMR0 interrupts disabling PORTAchange interrupts???
    Last Post: - 19th August 2008, 16:10
