remote code learning
Results 1 to 21 of 21
Threaded View
  1. #9
    Default Re: remote code learning
    Hey Dave,
    I'm not sure I follow you on this! Could you elaborate?
    I have found individual bit timing to not be that critical, but if you're off by a certain margin on each data bit & the space between each data bit, you're potentially off by a mile by the end of the complete data packet, and this really did make a huge difference.
    For example - if you're off by say 20% on each data bit, and the space between each bit, you're way off by the end of the packet.
    And this may/may not be impacted by your measurement technique. I.E. measureing bits directly from the encoder output or the output of an RF receiver or IR module with a relatively slow rise/fall time, so it's best to be as close as possible in my experience.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
  1. My code for TV remote and MIBAM for RGB control
    By idtat in forum Code Examples
    Last Post: - 12th January 2013, 21:52
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  5. Please help ? RF Remote Source code
    By sorasit46 in forum mel PIC BASIC Pro
    Last Post: - 25th April 2007, 15:40
