Quote Originally Posted by EE12212 View Post
but if i want to change to 100HZ i can't.. because prescale is in max (max=16) and PR2 is almost on max(max=255)..
how i could work with small frequencies?
You can't - this is a limitation of the CCP module which has only an 8-bit period register. This table is from the data sheet. With an 8MHz clock, the lowest frequency is 488Hz.
