18F25J11 RTCC & remappable pin options
Results 1 to 14 of 14
Threaded View
  1. #10
    May 2007
    I have been working with the NXP LPC11xx parts and they look really nice. A 32-bit part that is cheaper than most 8-bit PIC devices (as low as $0.65/10,000 for a 8kB/2kB/33-pin part). Some basic specs:
    # ARM Cortex-M0 processor, running at frequencies of up to 50 MHz and 48DMips
    # ARM Cortex-M0 built-in Nested Vectored Interrupt Controller (NVIC)
    # 32 kB (LPC1114), 24 kB (LPC1113), 16 kB (LPC1112), or 8 kB (LPC1111) on-chip flash programming memory
    # 8 kB, 4 kB, or 2 kB SRAM
    # In-System Programming (ISP) and In-Application Programming (IAP) via on-chip bootloader software
    # UART with fractional baud rate generation, internal FIFO, and RS-485 support
    # Two SPI controllers with SSP features and with FIFO and multi-protocol capabilities (second SPI on LQFP48 and PLCC44 packages only)
    # I2C-bus interface supporting full I2C-bus specification and Fast-mode Plus with a data rate of 1 Mbit/s with multiple address recognition and monitor mode
    # Up to 42 General Purpose I/O (GPIO) pins with configurable pull-up/pull-down resistors
    # Four general purpose 16/32-bit timers/counters with a total of four capture inputs and 13 match/PWM outputs
    # Programmable WatchDog Timer (WDT)
    # System tick timer
    # Serial Wire Debug
    # High-current output driver (20 mA) on one pin
    # High-current sink drivers (20 mA) on two I2C-bus pins in Fast-mode Plus
    # Integrated PMU (Power Management Unit) to minimize power consumption during Sleep, Deep-sleep, and Deep power-down modes
    # Three reduced power modes: Sleep, Deep-sleep, and Deep power-down
    # Single 3.3 V power supply (1.8 V to 3.6 V)
    # 10-bit ADC (400ks/S) with input multiplexing among 8 pins
    # GPIO pins can be used as edge and level sensitive interrupt sources
    # Clock output function with divider that can reflect the system oscillator clock, IRC clock, CPU clock, and the Watchdog clock
    # Processor wake-up from Deep-sleep mode via a dedicated start logic using up to 13 of the functional pins
    # Brownout detect with four separate thresholds for interrupt and one threshold for forced reset
    # Power-On Reset (POR)
    # Crystal oscillator with an operating range of 1 MHz to 25 MHz
    # 12 MHz internal RC oscillator trimmed to 1 % accuracy that can optionally be used as a system clock
    # PLL allows CPU operation up to the maximum CPU rate without the need for a high-frequency crystal. May be run from the main oscillator, the internal RC oscillator, or the watchdog oscillator.
    The software dev tools are C based but do come free with the purchase of the $30 LPC1114 LPCXpresso board. With this move, I am considering moving to MPLAB and C18/C30 and possibly abandoning BASIC altogether.
  1. Is this a K Type sensor?
    Last Post: - 21st November 2009, 13:55
  2. DS1820 with 16f688
    Last Post: - 23rd May 2009, 05:07
    Last Post: - 13th December 2008, 17:11
  5. Another RTC, DS1287
    Last Post: - 12th December 2006, 17:07
