18F25J11 RTCC & remappable pin options
Results 1 to 14 of 14
    I have the free version of C30 - so I'll probably start with that. How do you like the
    mikroBASIC ?
    I actually prefer C to BASIC. Do they have a version of C that supports this PIC? And,
    do you consider it better than C30?
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    May 2007
    I have been using mikroBASIC since I started with the PIC24/dsPIC33. mikroBASIC is closer to C than most any BASIC out there - with the exception of Swordfish. Realistically, there is nothing you can't do with mikroBASIC that can be done with C. There is a mikroC for dsPIC but I cannot comment on it as I am not a C user.
    Thanks for the feedback. I did try mikroBASIC several years back, and when comparing the
    code it produced to PBP & Proton, it totally sucked. Especially compared to Proton.
    Perhaps I should try it again, but I really do prefer C to BASIC - so I might give the mikroC
    compiler another look. That one wasn't exactly up to par the last time I tried it either.
    Swordfish totally rocks, but I'm a tad concerned about it being supported in the near
    future, and it's really depressing that it only supports the 18F series & needs that USB
    dongle.
    My work requires me to get things out like yesterday, and I can't/won't pay full
    boat for a replacement dongle in a pinch .. when it craps-out.
    Proton rocks too, but I'm not into installing beta software, that's a real pain in the
    pooter, for any compiler that hasn't offered registerd users an upgrade for many years.
    That really killed Proton here in the US.
    -Bruce
    tech at rentron.com
    May 2007
    I have been working with the NXP LPC11xx parts and they look really nice. A 32-bit part that is cheaper than most 8-bit PIC devices (as low as $0.65/10,000 for a 8kB/2kB/33-pin part). Some basic specs:
    # ARM Cortex-M0 processor, running at frequencies of up to 50 MHz and 48DMips
    # ARM Cortex-M0 built-in Nested Vectored Interrupt Controller (NVIC)
    # 32 kB (LPC1114), 24 kB (LPC1113), 16 kB (LPC1112), or 8 kB (LPC1111) on-chip flash programming memory
    # 8 kB, 4 kB, or 2 kB SRAM
    # In-System Programming (ISP) and In-Application Programming (IAP) via on-chip bootloader software
    # UART with fractional baud rate generation, internal FIFO, and RS-485 support
    # Two SPI controllers with SSP features and with FIFO and multi-protocol capabilities (second SPI on LQFP48 and PLCC44 packages only)
    # I2C-bus interface supporting full I2C-bus specification and Fast-mode Plus with a data rate of 1 Mbit/s with multiple address recognition and monitor mode
    # Up to 42 General Purpose I/O (GPIO) pins with configurable pull-up/pull-down resistors
    # Four general purpose 16/32-bit timers/counters with a total of four capture inputs and 13 match/PWM outputs
    # Programmable WatchDog Timer (WDT)
    # System tick timer
    # Serial Wire Debug
    # High-current output driver (20 mA) on one pin
    # High-current sink drivers (20 mA) on two I2C-bus pins in Fast-mode Plus
    # Integrated PMU (Power Management Unit) to minimize power consumption during Sleep, Deep-sleep, and Deep power-down modes
    # Three reduced power modes: Sleep, Deep-sleep, and Deep power-down
    # Single 3.3 V power supply (1.8 V to 3.6 V)
    # 10-bit ADC (400ks/S) with input multiplexing among 8 pins
    # GPIO pins can be used as edge and level sensitive interrupt sources
    # Clock output function with divider that can reflect the system oscillator clock, IRC clock, CPU clock, and the Watchdog clock
    # Processor wake-up from Deep-sleep mode via a dedicated start logic using up to 13 of the functional pins
    # Brownout detect with four separate thresholds for interrupt and one threshold for forced reset
    # Power-On Reset (POR)
    # Crystal oscillator with an operating range of 1 MHz to 25 MHz
    # 12 MHz internal RC oscillator trimmed to 1 % accuracy that can optionally be used as a system clock
    # PLL allows CPU operation up to the maximum CPU rate without the need for a high-frequency crystal. May be run from the main oscillator, the internal RC oscillator, or the watchdog oscillator.
    The software dev tools are C based but do come free with the purchase of the $30 LPC1114 LPCXpresso board. With this move, I am considering moving to MPLAB and C18/C30 and possibly abandoning BASIC altogether.
    EE12212's Avatar
    EE12212 Guest
    Default Pwm frequency
    hello
    thanks bruce for this code!
    i have a question for you.. if i want to change the frequency to 500Hz.. i do..
    T2CON = %00000110 ' TIMER 2 ON/ PRESCALE 1:16
    PR2 = 250 ' SETUP FOR 500HZ
    but if i want to change to 100HZ i can't.. because prescale is in max (max=16) and PR2 is almost on max(max=255)..
    how i could work with small frequencies?
    best regards
    Pedro Rodrigues
    May 2007
    Quote Originally Posted by EE12212 View Post
    You can't - this is a limitation of the CCP module which has only an 8-bit period register. This table is from the data sheet. With an 8MHz clock, the lowest frequency is 488Hz.
    Use the newer 16F1 enhanced core devices.
    Timer2 has a 1:64 prescaler, so you can get PWM down to 62hz with a 4mhz OSC.
    __________________
    france
    Default Re: 18F25J11 RTCC & remappable pin options
    Hello
    I want to use your example on a 18f26j50, but instead of displaying the date
    I want to record data in an external eeprom.
    Must convert it before writing to the eeprom or convert a reading
    of the eeprom before sent to the PC? bcd format
    and that the changes to make to pass a 16F628 to 18f26j50
    Thank you for your help
  1. Is this a K Type sensor?
    Last Post: - 21st November 2009, 14:55
  2. DS1820 with 16f688
    Last Post: - 23rd May 2009, 06:07
    Last Post: - 13th December 2008, 18:11
  5. Another RTC, DS1287
    Last Post: - 12th December 2006, 18:07
